> What do you guys think, 1st gen 3sge head on a 5sfe?
post Feb 15, 2009 - 8:17 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Of course I will be boosting this so technically it will be a 5sgte. But I was wondering what the pros and cons are with the 1st gen 3sge head? I like the intake manifold on the 3sge but I doubt it will flow as good as the 3sgte manifold.
I have access to dirt cheap 3sge heads and it would be an awesome project.
94 Celica gt white (sold)
- bccentaur3   What do you guys think, 1st gen 3sge head on a 5sfe?   Feb 15, 2009 - 8:17 PM
- - RavenAegis45   hmm well it might flow better than it's 3S-GTE...   Feb 15, 2009 - 11:04 PM
- - bccentaur3   Actually i might opt and get a 3rd gen 3sge head o...   Feb 15, 2009 - 11:48 PM
|- - RavenAegis45   QUOTE (bccentaur3 @ Feb 15, 2009 - 11...   Feb 16, 2009 - 12:23 AM
- - trdproven   Hardtarget i think has a 5sgte and his car is a mo...   Feb 16, 2009 - 6:47 AM
- - delusionz   Would love to see what a 5S-GE does NA.... 3S-GE ...   Feb 16, 2009 - 8:05 AM
- - Cuts_the_Pilot   well worry no more. a mate of mine has done it be...   Feb 16, 2009 - 8:23 AM
- - trdproven   3s and 5s puts best of both worlds.   Feb 16, 2009 - 9:49 AM
- - bccentaur3   Cuts, so your buddy ran the stock 3sfe ecu with a ...   Feb 16, 2009 - 1:06 PM
- - bdawgbp1   Someone please let me know as I am getting ready t...   Feb 23, 2009 - 3:56 AM
- - Cuts_the_Pilot   no he used the stock 3s-ge ecu running the 5s-ge c...   Feb 23, 2009 - 3:29 PM
- - bdawgbp1   So are you saying I can use my stock 5S-FE ECU, in...   Feb 23, 2009 - 6:41 PM
- - Cuts_the_Pilot   going your way around you might be ok using your e...   Feb 23, 2009 - 9:49 PM
- - bccentaur3   how do you plan to use the 3sge distributor?   Feb 23, 2009 - 10:05 PM
- - Cuts_the_Pilot   what would be the problem using it?   Feb 24, 2009 - 2:04 AM
- - bccentaur3   5sfe ecu with 3sge ignition system?   Feb 24, 2009 - 2:07 AM
- - bdawgbp1   So do I need to change the distributor also. Also ...   Feb 24, 2009 - 2:27 AM
- - Cuts_the_Pilot   i havnt checked for sure but i cant see the dizzy...   Feb 24, 2009 - 8:15 AM
- - bdawgbp1   Thanks for the info. I will be using a 3S-GTE head...   Feb 24, 2009 - 1:43 PM
|- - HARDTARGET   QUOTE (bdawgbp1 @ Feb 24, 2009 - 1:4...   Feb 24, 2009 - 3:33 PM
- - Cuts_the_Pilot   what he said...i think it was mentioned in my post...   Feb 24, 2009 - 5:56 PM
|- - bdawgbp1   QUOTE (Cuts_the_Pilot @ Feb 24, 2009 - 4...   Feb 24, 2009 - 10:05 PM
- - bdawgbp1   Cool beans - anything else? I'm trying to get ...   Feb 24, 2009 - 6:09 PM
- - bccentaur3   Hes saying if you want a better flowing head get a...   Feb 24, 2009 - 10:31 PM
- - bdawgbp1   Unfortunately I already have the 3S-GTE head. Can ...   Feb 25, 2009 - 1:36 AM
|- - presure2   QUOTE (bdawgbp1 @ Feb 25, 2009 - 1:3...   Feb 25, 2009 - 4:30 AM
- - Cuts_the_Pilot   if you alreayd have the gte head use what you have...   Feb 25, 2009 - 4:25 AM
- - bccentaur3   If you plan on going NA with the build use a 5sfe ...   Feb 25, 2009 - 3:32 PM
- - bdawgbp1   Yeah - I know. You are right - there wasn't al...   Feb 25, 2009 - 4:16 PM
- - bccentaur3   Piece the turbo kit using 3sgte stock parts with r...   Feb 25, 2009 - 4:22 PM
- - bdawgbp1   No I haven't read about your build - but I...   Feb 25, 2009 - 4:37 PM
|- - DEATH   QUOTE (bdawgbp1 @ Feb 25, 2009 - 3:3...   Feb 25, 2009 - 5:31 PM
- - bccentaur3   Unless you have a 3rd gen head, then no.   Feb 25, 2009 - 5:28 PM
- - bccentaur3   Death, did you get my pm about the turbo and heats...   Feb 25, 2009 - 5:39 PM
|- - DEATH   QUOTE (bccentaur3 @ Feb 25, 2009 - 4...   Feb 26, 2009 - 12:49 PM
- - bdawgbp1   Hell yeah!!! Let me see if I can go di...   Feb 25, 2009 - 5:43 PM
Lo-Fi Version Time is now: September 14th, 2026 - 4:56 PM
