> oil restrictor pill?, apparently im putting more oil into my turbo than required.
post Feb 19, 2009 - 11:40 AM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
my tuner informed me that im putting more oil out than i should. told me to look for an oil restrictor pill.
i hate to say that i dont know anything really about those. guess im still a newb in some areas. any advice or input on what or where i should get this?
1994 Toyota Celica ST Turbo
1991 Toyota MR2
MySpace
Replies (1 - 9)
post Feb 19, 2009 - 11:48 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Your tuner is referring to an oil re stricter. You buy it and put it with your oil feed line. You can get one at ATPturbo
94 Celica gt white (sold)
post Feb 19, 2009 - 1:20 PM
Nial
Joined Aug 25, '08
From England
Can you have "too much" oil going into a turbo????...sounds a bit odd to me...better too much than not enough. Surely you want the best oil flow possible going into your turbo helping to keep it cool and run smoothly????
This post has been edited by Nial: Feb 19, 2009 - 1:21 PM
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Feb 19, 2009 - 1:23 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
Of course, too much oil can sometimes be just as bad as not enough oil.
post Feb 19, 2009 - 2:19 PM
Muggs
Joined Sep 13, '06
From St. paul, MN
Too much oil increases the chances of oil blowing past the turbo's seals, getting into your intake tract.
Oil restrictors are cheap and pretty easy to install.
post Feb 19, 2009 - 2:40 PM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
ok cool. im ordering it now
thanks bccentaur3
1991 Toyota MR2
MySpace
post Feb 19, 2009 - 2:46 PM
its not so much a quantity overall, its too much oil pressure into the turbo, which is why you use a restricter @ the turbo to reduce the oil pressure within it
post Feb 19, 2009 - 4:26 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
you only need one if your running a ball bearing turbo, ball bearings need vastly less oil then plain bearing.
saying this people over here who have put bb turbos on their 3sgte havnt put a restricter in and years later no blown seals....3s oil pumps arnt the best things in the world.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Feb 19, 2009 - 6:35 PM
QUOTE (Cuts_the_Pilot @ Feb 19, 2009 - 4:26 PM) *
People without ball bearing turbos need them too, its not just limited to BB turbo applications
its not just about quantity its also about pressure
The OP is running a 7afte, 7afes are known to have a higher oil pressure than the range of pressure which should be seen at the turbo.
This post has been edited by playr158: Feb 19, 2009 - 6:37 PM
post Feb 19, 2009 - 7:46 PM
TRD_Ian
Joined Aug 19, '08
From New Brunswick
me and a buddy made on for real cheap, he gave me a brace fitting and i filled it with with brazing and we drilled it out, and it has worked great for him i guess
i hate snow, missing my celica
Lo-Fi Version Time is now: August 31st, 2026 - 4:08 PM
