> FS: Parting Out 5SFE engine, CHEAP PARTS! everything must go!
post Feb 21, 2009 - 3:35 AM
6strngs
Joined May 12, '06
From Wilmington, NC
Title says it all. I have a blown 5sfe that I'm parting out. The bottom end is blown due to metal shards getting into it and chewing up the pistons and cylinder walls. It's probably still rebuildable since the gouges weren't that deep, you'd just have to go with .020 or .040 oversize pistons ande overbore it. I'll let the bottom end go for cheap. The top end is still in good shape. Though I'd recommend rebuilding it before using it since it's got 162K on it. I have manifolds, etc. let me know what you need and I'll let you know what I've got.
At this time, I'm just selling the engine parts. I may have some other parts that I need to get rid of too. if I do, I'll post them here. Here's just a few of the parts:
5sfe intake manifold
5sfe stock exhaust manifold w/ heat sheilds
5sfe bottom end, block, crank, pistons, rods - $20 picked up, expect a high-ish shipping charge
5sfe head worked good on my car, has 162K on it. no cams. $35 + ship!!!
stock alternator, dirty but works good
brackets, for PS pump, Alternator, passenger side axle, etc.
valve cover, good condition, not painted
OBD1 (94-95) Manual transmission wiring harnesses. I have one california spec, and one federal spec. both are 98% complete. AFAIK they are both only missing one connector each. they may also be missing the rubber boot where it goes into the firewall. $50 each + shipping
Make an offer on anything! I'll let stuff go cheap to clear my garage. I especially want the engine itself out. Let me know what you need, I've most likely got it if it relates to the engine.
This post has been edited by 6strngs: Mar 10, 2009 - 8:38 PM
- 6strngs   FS: Parting Out 5SFE engine   Feb 21, 2009 - 3:35 AM
- - 94celicadude   how much would you want for cams? and what year is...   Feb 21, 2009 - 7:12 PM
- - 6strngs   The engine is from a 94 california spec. Most part...   Feb 21, 2009 - 8:06 PM
- - 6strngs   first post updated with a couple parts. That's...   Feb 24, 2009 - 11:00 AM
- - 6strngs   cams sold!!! Make me an offer on anyt...   Mar 10, 2009 - 8:39 PM
- - 6strngs   bump   Mar 16, 2009 - 9:11 PM
- - 92-gt   Do you have a starter? If so, hoe much??   Mar 16, 2009 - 9:22 PM
- - 6strngs   sorry, don't have a starter that works   Mar 17, 2009 - 1:31 AM
- - AzNbOiFrM9i6   what kinda intake you have?   Mar 17, 2009 - 2:49 AM
|- - 6strngs   QUOTE (AzNbOiFrM9i6 @ Mar 17, 2009 - 12...   Mar 17, 2009 - 12:19 PM
- - NgoFcukinWay   do you have a BVSV?   Mar 17, 2009 - 9:21 AM
- - NgoFcukinWay   it's that blueish/green thing on the far right...   Mar 17, 2009 - 1:25 PM
|- - 6strngs   QUOTE (NgoFcukinWay @ Mar 17, 2009 - 11...   Mar 17, 2009 - 9:31 PM
- - azn87   do u have the dp with the cat on it? for lewfx   Mar 17, 2009 - 4:30 PM
Lo-Fi Version Time is now: August 20th, 2026 - 10:59 AM
