Feb 22, 2009 - 6:40 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
Ok so my car died out the other day. i got in, checked the ignition coil since there was no spark, it came in at .6-.7 ohms (according to bgb it should be around 1.75) so i went ahead and replaced. also did cap, rotor, plugs and wires. thought i would also replace fuel filter while i was at it. there was obviously a pretty decent amount of fuel pressure when i went to break the filter free so i wasnt sure if that would have been the sign of a faulty fuel pump either. it still wont start, can anyone lend any advice?
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." ![]() |
FreddyTheOthaMeat Could use some help Feb 22, 2009 - 6:40 PM
Bitter do you still have no spark? Feb 22, 2009 - 7:45 PM
FreddyTheOthaMeat yea i got spark now. thats why its kinda confusin... Feb 23, 2009 - 9:08 AM
presure2 pull the distributor cap, verify the rotor turns 3... Feb 23, 2009 - 9:17 AM
FreddyTheOthaMeat Ok so it turned out to be the timing belt, got it ... Mar 12, 2009 - 9:16 AM
FreddyTheOthaMeat Oh and the misfire is on the exhaust side as you c... Mar 12, 2009 - 1:45 PM
soulshadow See if the timing belt is actually time right. You... Mar 12, 2009 - 2:08 PM
FreddyTheOthaMeat QUOTE (soulshadow @ Mar 12, 2009 - 1... Mar 12, 2009 - 6:28 PM
FreddyTheOthaMeat QUOTE (FreddyTheOthaMeat @ Mar 12, 2009 ... Mar 16, 2009 - 12:48 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:43 AM |
