> IllumiNite subwoofer wiring, how to
post Feb 23, 2009 - 10:44 AM
pengsm
Joined Jun 27, '08
From oklahoma
sup guys, look i have a 10" Dual subwoofer i already got it hook up, but inside the box there's a, they call it, IllumiNite lighting that can be wire to a 12v source. i read the instructions they said donnot hook it up directly to battery as that will drain your battery so....
the back of the sub already have a "ON" and "OFF" switch for the IllumiNite
how do you hook it up?
and what kind of wire do you use?
hEElp!!
Replies (1 - 19)
post Feb 23, 2009 - 11:40 AM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
run speaker wire to your power antenna wire on your HU. and ground it so when you turn your HU on, the likes will turn on.
post Feb 23, 2009 - 11:59 AM
pengsm
Joined Jun 27, '08
From oklahoma
QUOTE (JustinCapps @ Feb 23, 2009 - 11:40 AM) *
hey if you dont mind can you show me a picture or a diagram, not reallie sure what a HU is or how to ground the speaker wire.
post Feb 23, 2009 - 12:17 PM
pengsm
Joined Jun 27, '08
From oklahoma
holdup what color is the power atenna wire?
post Feb 23, 2009 - 12:30 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
your antenna power wire should be blue... the lil on that runs from the stereo to the amp for yur subs... thats your pos. and run your neg. is the base of the car.. i did it for the lights on my car..
the HU is the headunit
This post has been edited by JustinCapps: Feb 23, 2009 - 12:31 PM
post Feb 23, 2009 - 12:46 PM
pengsm
Joined Jun 27, '08
From oklahoma
QUOTE (JustinCapps @ Feb 23, 2009 - 12:30 PM) *
blue wire isn't that the remote wire?? or is it the same thing??
(sorry kinda new at this kinda thing)
post Feb 23, 2009 - 12:51 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
yeah man, sorry i should of said that.. but yes that wire is the same. smile.gif
hook it up and pics! interested!
post Feb 23, 2009 - 1:07 PM
DEATH
Joined Dec 19, '07
From tx
It's usually not the same wire actually. There should be two blue wires back there one will be for the antennae [which only comes on with AM/FM radio - you wouldn't want to do this]. The blue wire with white stripe is your remaote which is already run to your amp so why not use that? One thing comes to mind - if the lights aren't shielded well you might catch some signal noise which would be bad - but try it first. If that doesn't work there should be an illumination [Orange IIRC?] wire back there that will turn the subs neons on when you turn at least the first click on your headlight stalk wink.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Feb 23, 2009 - 1:17 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
lol thats probably a good thing to know lol
post Feb 23, 2009 - 1:25 PM
pengsm
Joined Jun 27, '08
From oklahoma
QUOTE (DEATH @ Feb 23, 2009 - 1:07 PM) *
so you just connect the positive to the blue (remote wire), which also connects to the deck and the amplifier, right?
QUOTE (JustinCapps @ Feb 23, 2009 - 12:51 PM) *
alright yea, so you got the blue wire from your amplifier to your deck, and you just connect the illumiNte wire with it?
post Feb 23, 2009 - 1:48 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
post Feb 23, 2009 - 1:53 PM
pengsm
Joined Jun 27, '08
From oklahoma
QUOTE (JustinCapps @ Feb 23, 2009 - 1:48 PM) *
alright, and you said ground the wire too, now that will be the negetive wire. what color wire will you ground that neg. wire to?
and what wire gauge will you recommend?
post Feb 23, 2009 - 2:05 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (pengsm @ Feb 23, 2009 - 12:25 PM) *
Yes and Yes. Assuming your amp is in the trunk already it should be easy enough to hook up it's blue wire to the + on the lights and the black wire to the - on the lights
Edit: Listen for signal noise before and after this operation - there is a small chance the lights aren't shielded well enough and will change the sound
This post has been edited by DEATH: Feb 23, 2009 - 2:06 PM
EXT: WRC/TRD/404
post Feb 23, 2009 - 2:07 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
gauge doesnt matter just so long as its no tooo small.
connect a wire from the chassic of the car, then run it to your neg.
post Feb 23, 2009 - 2:16 PM
pengsm
Joined Jun 27, '08
From oklahoma
QUOTE (JustinCapps @ Feb 23, 2009 - 2:07 PM) *
ah....what do you mean "chassic"??
QUOTE (DEATH @ Feb 23, 2009 - 2:05 PM) *
shielded??
post Feb 24, 2009 - 12:50 AM
korban
Joined Feb 5, '09
From New Zealand
He means 'Chassis', as in the metal shell of your car. It is a return path for current to your battery.
So just connect it to any metal bolt etc nearby.
You might also want to check that your headunit can supply (check your manual if you have it) the current required by the illuminite light (hopefully it says how much current it requires). My head unit can only supply 300mA through it's remote wire, as it's only meant to be a signal to turn the amp on, and not a power supply to run the amp.
post Feb 24, 2009 - 5:20 AM
gt_driFFter
Joined Nov 29, '04
QUOTE (DEATH @ Feb 23, 2009 - 3:05 PM) *
Subwoofers operate in a frequency range that won't be affected by something like a neon light tube, so this is not necessary.
As far as original question goes, Death nailed it.
post Feb 24, 2009 - 6:28 AM
trdproven
Joined Aug 2, '05
From Guam
pretty simple, run it to your amp where the 12v and the negative is. this way you pick up the remote turn on and off that way no drainage. This is how some built in lights run, through the power it gets from the amp.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 24, 2009 - 9:25 AM
pengsm
Joined Jun 27, '08
From oklahoma
thnx guys i did, i did it "DEATH"'s way and it worked, hell yea
post Feb 25, 2009 - 5:10 AM
korban
Joined Feb 5, '09
From New Zealand
QUOTE (trdproven @ Feb 24, 2009 - 6:28 AM) *
Isn't the 12V at the amp always hot, and the remote wire switches an internal relay?
I'd probably wire up an external relay using the remote wire to turn it on, and the amp's power wire's for power.
pengsm: Keep an eye on your head unit and make sure it's not getting too hot, that remote line probably isn't fused, at least not externally accessible. You wouldn't want to kill your remote line, that would suck.
Lo-Fi Version Time is now: September 1st, 2026 - 3:22 PM
