> Question About the Radiator
post Feb 27, 2009 - 4:59 PM
RavenAegis45
Joined Jun 25, '08
From CA
Ok so I was doing a normal Oil change on my car and I decided to check my Radiator fluid levels and they all seemed fine but while I was checking out my Radiator I noticed the Upper Tank was starting to show small whitish cracks. I consulted my mechanic friend and he said my radiator was getting old and I'll eventually need to replace it. My question is would I be able to just replace the tanks of should I replace the entire thing?
post Feb 27, 2009 - 5:27 PM
azian_advanced
Joined Apr 18, '05
From Calgary
you can either replace the entire radiator with another one, or take it to a radiator shop and they can repair the upper or lower tanks for you.
post Feb 28, 2009 - 1:32 AM
trdproven
Joined Aug 2, '05
From Guam
Repairs only last for a while - it is inevitable, instead of paying someone to repair, just get it replaced.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 28, 2009 - 3:18 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Get it replaced with a high flow ally one.
post Feb 28, 2009 - 8:23 PM
RavenAegis45
Joined Jun 25, '08
From CA
well my current Radiator is a brownish color and you can see the small stress cracks, But my Car's an Auto and I read somewhere that the Manual Models had a different Radiator Design? is that true?
This post has been edited by RavenAegis45: Feb 28, 2009 - 8:23 PM
post Mar 1, 2009 - 4:24 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The automatic transmission required a cooler, which attaches to the transmission with a pair of hard lines to the bottom of the radiator. Most aftermarket radiators will have the transmission cooler, and simply leave it capped off when installed in a manual car.
So yes, make sure your new radiator has an oil cooler.
post Mar 1, 2009 - 11:26 AM
RavenAegis45
Joined Jun 25, '08
From CA
QUOTE (Galcobar @ Mar 1, 2009 - 4:24 AM) *
Ok thanks for the heads up
Lo-Fi Version Time is now: August 1st, 2026 - 9:59 AM
