> Question for those who replaced radiator with A/T
post Feb 27, 2009 - 7:18 PM
valerit1
Joined May 2, '06
From Nevada
Hi,
Did you replace the rubber hoses which connect the transmission and the built-in cooler in the radiator or reused the old ones?
Where did you get those, if replaced? Did you replace the O-ring for the fan swith in the radiator bottom?
Where did you get it?
Thanks,
Val
post Feb 27, 2009 - 11:25 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (valerit1 @ Feb 27, 2009 - 7:18 PM) *
Hi,
Thanks,
Val
Wow, I think you put this in the wrong spot...anyways. Im getting ready to do this....again.
Ok, um I reused mine, inspected them, they still looked good. Im sure that you can get rubber hosing from almost anywhere. dont know if there is a PSI limit youd need though (wouldnt think so).
Secondly, its good practice to replace seals, gaskets, packings, etc with new ones when you mess with them. Does this mean you have to do it, no, personal preference. I try to, but you can buy an o-ring kit from an auto store (pep boys, autozone)
post Mar 3, 2009 - 2:43 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
For those transmisson lines, if there cracked or broken. You have to replace them with Power steering lines to hold the fluid and the beatings since it is underneath your car. You cannot use vaccum lines or fuel line they must be at least power steering lines of same dimension or something as tough as power steering line.
post Mar 3, 2009 - 4:53 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Just curious, anyone replace those lines with a rubber/stainless lines?
Lo-Fi Version Time is now: August 22nd, 2026 - 7:59 PM
