Mar 5, 2009 - 4:50 PM
Enthusiast ![]() ![]() Joined Dec 26, '05 From So Cal Currently Offline Reputation: 1 (100%) |
Hey guys, I'm hoping you can help me with this problem. I noticed that my A/C wasn't working, and discovered that the magnetic clutch does not engage when I press the button inside the cabin, even though the light comes on. So I got my digital voltmeter out and checked the wire going to the compressor. There is no voltage going to the compressor with the A/C button on or off, so I suspect a fuse or wiring problem. Do you know where the fuse is for this circuit? Have any of you experienced this problem before? I appreciate any help. Thanks
celicamike A/C not working Mar 5, 2009 - 4:50 PM
stephen_lee i belive the fuse is AC in the engine bay Mar 6, 2009 - 1:00 AM
soulshadow If the fuse doesn't solve it, take the belt of... Mar 9, 2009 - 10:46 PM
trdproven Timing would be a problem if the ac clutch only en... Mar 10, 2009 - 1:07 AM
celicamike QUOTE (trdproven @ Mar 9, 2009 - 11... Mar 20, 2009 - 12:44 PM
celicamike Thanks for the advice fellas, I'll start by ch... Mar 12, 2009 - 12:40 AM
trdproven Tell us your symptoms, read my post and tell me if... Mar 14, 2009 - 11:41 AM
stephen_lee i believe hes talking about a transistor in the A/... Mar 21, 2009 - 12:20 AM
trdproven ^ Right, transistor has more than one link, I thin... Mar 21, 2009 - 10:50 AM
celicamike QUOTE (trdproven @ Mar 21, 2009 - 8... Mar 24, 2009 - 12:39 AM
trdproven Good to hear - a leak tester works wonders with th... Mar 24, 2009 - 1:15 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 24th, 2026 - 2:09 PM |
