Mar 12, 2009 - 8:08 PM
![]() Enthusiast ![]() ![]() Joined Jun 28, '05 From MB, Canada Currently Offline Reputation: 1 (100%) |
It seems like as soon as i fix something on my car, something else goes. This time it's the power steering i believe. As i turn my wheel, there are intermittent periods that lack power assistance and require a significant amount of force just to turn the wheel. At these points i also have to use manual force to turn the wheel back into a straight position. This doesn't happen all the time, just at particular points in the steering radius. (included a picture to illustrate.)
I checked the fluid and it is full, but quite dirty. 'Murky' would be the word i use to describe it. The belt squeaked last winter, but stopped after some belt dressing was applied. Belt hasn't squeaked since. Any advice as to what i should suspect is greatly appreciated. |
Mar 13, 2009 - 12:15 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
sounds like your rack and pinion is out. A bad pump will squeek and make constant require force to turn the steering wheel.
Mar 18, 2009 - 11:10 PM
after fooling around some with the power steering pump, I think you are right. I'll have to find a new rack and pinion and throw it on it looks like. Thanks for the help.
| Lo-Fi Version | Time is now: September 1st, 2026 - 5:25 AM |
