> Need Help with Turbo 4AGE
post Mar 12, 2009 - 8:36 PM
jmeyer
Joined May 14, '08
From Grand Island NY
I recently pruchased a 96 corolla with a turbo'd silver top 4age. Since then I have driven it for a few hours and it runs fine. However tonight I was out and I noticed when I got on the throttle, the engine would cut out at 4000 rpm and the oil pressure light would kick on, however if I let off on the throttle and it dropped back down to 3000 rpm it went off. I was checking the boost gauge and it was spooling fine. The car just lost all pull after 4000 rpm. Checked the oil levle and it was fine. It was cold out (around 32f) but I don't think that would cause this. I'm runnig 7 psi of boost and 93 octane. Any suggestions would be greatly appreciated.
Heres all the motor work:
4A-GE 20-Valve Silvertop Engine (this engine has less than 15,000 miles since rebuild)
· Complete Engine Rebuild with OEM 4A-ZE 8:5:1 Pistons, OEM Water Pump, OEM Timing Belt, Rod Bearings, Main Bearings, OEM Engine Gasket Set, ARP Rod Bolts, ARP Main Studs, ARP Flywheel Bolts, and TRD Full-Metal Head Gasket
· 4A-GE 20-Valve Blacktop Wiring Harness and E.C.U.
· Custom Turbo Kit with T3-Super 60 Turbo, HKS Blowoff Valve, Tial-type 38mm Wastegate, 380cc Injectors, SplitSecond Air/Fuel Calibrator, Aluminum Intake Pressure Plenum, and all silicone Intercooler Couplers
· External Oil Cooler with Oil Filter Relocater
· New Radiator
· All new Hoses and Drive Belts
· Complete TRD Engine Mount Kit
· TDR Spark Plug Wires
· NGK Iridium Spark Plugs
· OEM Distributor Cap and Rotor Button
· MSD sci Ignition Box
· Manual Boost Controller set @ 6psi
1994 Supra TT
1999 Cadillac Escalade (winter ride/tow truck)
1994 Celica GT-4 Converted
1998 Celica GT-4 Converted
1987 Corolla FX
1986 Corolla AE86 (Next Project)
Lo-Fi Version Time is now: July 30th, 2026 - 9:22 AM
