Mar 14, 2009 - 12:10 PM
Enthusiast Joined Jan 13, '09 From Maryland Currently Offline Reputation: 0 (0%) |
I have a 1997 Celica GT and I was wondering what size the front speakers are, I've looked online and some websites are saying that the size is 6.5. Is that correct? Thanks for the help.
Mar 14, 2009 - 12:17 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
Mar 14, 2009 - 1:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
its a 8 inch no ands ifs or butts, if you get anything smaller you need adapter rings...
Apr 6, 2009 - 7:33 PM
Enthusiast ![]() Joined Nov 6, '08 From locust grove, va Currently Offline Reputation: 0 (0%) |
Apr 6, 2009 - 7:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '07 From Washington Currently Offline Reputation: 9 (100%) |
its a 8 inch no ands ifs or butts, if you get anything smaller you need adapter rings... is it the same on all 6gc's? cause mine are defiantly 6.5in. The fronts come factory with 6.5", but you can fit up to an 8" speaker. -------------------- |
Apr 6, 2009 - 10:45 PM
Enthusiast ![]() Joined Apr 27, '08 From Michigan Currently Offline Reputation: 0 (0%) |
Well, If you have a 6 speaker system (two in each door and two in the back seat) then yes they are 6.5". However, If you have the 8 speaker system (three in each door and two in the back seat) then they are most definitely 8".
They are also a Woofer. not a woofer/mid or a full range speaker. If you go with a 6 or 6.5 coax it will without a doubt sound like $%^&! I know, I've got a 97 vert with the 8" and my speaker surrounds (foam) rotted out. I put 6" in and they sound really bad, compared to the factory ones. Also the factory ones are 2ohm impedance not 4 or 8 ohm--this really affects sound quality too. I'm still saving up to get the factory ones, lowest I've found from toyota are $250 each but I'm fairly sure that includes the housing. Hope this helps. |
Apr 7, 2009 - 11:26 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
If you have the 8" speakers, you can cut them to make them into adapters for a new set of 6.5" speakers. Cut out all of the cone so you're down to just the metal. If you cut out the driver and everything, the ring is just the right size to hold a 6.5" speaker. Did it at home with a dremel when I put new speakers in the 'vert, took just a few minutes.
-------------------- 1999 Celica GT
| Lo-Fi Version | Time is now: May 7th, 2026 - 10:43 AM |
