> 7th gen TRD shifter not fitting
post Mar 16, 2009 - 3:41 AM
sugarfree
Joined Dec 21, '05
From dallas
It doesnt line up with the existing holes. The car is being converted from an auto to manual. Any reason why the holes are not lining up or why the 7th gen shifter is not working...from what i read, the 7th gen trd shifter should work for our cars correct?
post Mar 16, 2009 - 9:11 AM
the 7th gen short shifter works, I don't think the 7th gen TRD one does.
post Mar 16, 2009 - 10:37 AM
DEATH
Joined Dec 19, '07
From tx
Actually I thought the 6th and 7th gen TRD shifters were the same part - hence the spacers. Could be wrong tho
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Mar 16, 2009 - 12:01 PM
blu94gt
Joined Mar 23, '05
From Kansas City
No I think the 6th and 7th gen TRD's are different, the spacers are just to bring it up since the linkage geometry is different. Plus isn't the 7th gen TRD for a 6 speed? (not that it makes much difference other than wider range for putting in reverse)
1999 Celica GT
post Mar 16, 2009 - 12:43 PM
sugarfree
Joined Dec 21, '05
From dallas
dangit!!!!
post Mar 16, 2009 - 1:48 PM
Culpable04
Joined Apr 17, '06
From New Jersey
what you can do is, try to get the big plastic peice of a 6th gen and swap the shaft from the 7th gen TRD, that will give you a TRD short shifter and it'll line up with the holes.
the only reason why it doesn't fit is because of the interior design of both cars is completely different so the plastic has to accomodate to different sourrounding.
post Mar 27, 2009 - 10:08 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
dont use the shifter asembly. just the shaft itself
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 27, 2009 - 2:39 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
i got my oem shifer assembly took it out for the trd short kit
Lo-Fi Version Time is now: August 31st, 2026 - 2:39 PM
