Mar 18, 2009 - 6:54 PM
Enthusiast ![]() Joined Nov 5, '02 From Illinois Currently Offline Reputation: 2 (100%) |
I have a 94 Celica GT. I recently repainted my engine bay, completely took all the power steering lines out of the bay pretty much everything except for the steering rack. I put it all back together filled it with dextron tranny fluid and then bled the system turning by the wheel back and forth tell it hit the stops. The pump was working fine I could see the fluid flowing through the resivior. I set the car down and drove it out of the garage and it didn't have any power steering. The pump makes no noise, I open the resivior and I cannot see any fluid moving. I got a used pump from the junkyard put it in, the exact same thing happened. I am completely baffled. Any Ideas on whats going on? Thanks for the help in advance.
This post has been edited by rsos1: Mar 18, 2009 - 6:56 PM |
rsos1 Crazy Power Steering Problem please help Mar 18, 2009 - 6:54 PM
playr158 well to start off you should have used power steer... Mar 18, 2009 - 7:42 PM
Remy Our cars take ATF fluid for the power steering, at... Mar 18, 2009 - 8:32 PM
rsos1 no leaks resivior is full Mar 19, 2009 - 8:18 PM
pittfirefighter has to be a clog in the line... obviously its not ... Mar 20, 2009 - 3:50 AM
Bitter is the pulley turning? Mar 21, 2009 - 10:03 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 31st, 2026 - 9:17 AM |
