Dec 11, 2012 - 1:25 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
Your racecar don't need my racecar's trd bumper, you'd break it more often than I do. Trd LSD from a 1zz mr2?
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 11, 2012 - 1:53 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
Your racecar don't need my racecar's trd bumper, you'd break it more often than I do. Trd LSD from a 1zz mr2? gimme it. now. I dont remember what it came out of. All I remember is the 17k mileage on it -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Dec 12, 2012 - 2:48 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
They are fantastic. I am however having an issue with movement in the rear larger bushing. Im sure it has to do with the sleeve (crash tube) that went with the stock bushings but had to be destroyed upon disassembly. What does the sleeve / crash tube look like? I'm probably going to be getting these bushings in the spring. |
Dec 12, 2012 - 3:42 PM
So after the install of them I realized I should have taken pictures, and that dustin was partially right when saying the crash tubes are worthless.
The torque spec for that rear bolt is around 150ft lbs, and at that point, you are compressing the metal pocket the mount is in, so at that point it wont really have any play. I see the sleeve as more of a security measure that in the case that something loosens, that rear mount will stay in place. Now for the install I will do my best to explain without pictures. For the crash tubes, the "right" method for installing them would be to drop the subframe and drop the tubes in from the top. And in my quest to find a way NOT to drop the subframe I did it this way: Since the crash tubes from toyota are fairly thin in thickness, I put them into the bushing hole (arm uninstalled). There are two different ends to the tube. One is tapered in and the other tapered out. The tapered in end would be facing down upon installation. Here is where my lazy crafty...ness came into play. When the tube is centered in the bushing, about 1/4 of the tube sticks out on either end. Having it like this will NOT allow you to pop in the mount in the pocket...there just isnt the clearance for that. (hence why the proper way is to drop them in from the top) SO. I took a mallet and hammered both of the ends of the tube inward and so they would be flush with the bushings metal center. At that point, the arm will be able to be installed, and when aligned, I took a screw driver and pryed back out the knocked in lower end, and took a long screwdriver and hit the upper knocked in end so that it would be unfold back to straight. does that make sense? I really should have taken pictures. and this will more than likely NOT be able to be done with those thicker crush tubes. Those would require the subframe to be dropped. This post has been edited by Tigawoods: Dec 12, 2012 - 3:43 PM -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Dec 12, 2012 - 4:39 PM
Very interesting method haha...glad it worked out for ya though!
Dec 25, 2012 - 11:27 AM
Enthusiast Joined Dec 24, '12 From Gaithersburg, MD Currently Offline Reputation: 0 (0%) |
dude, hoping to see your sick celica someday in the spring. you don't live too far from me. Gotta start on mines soon.
-------------------- 09 scion xd - 5spd- bbs- coilovers- exhaust- intake
94- Celica Gt 5spd- Stock for now |
Dec 26, 2012 - 8:52 PM
hopefully itll be done and back down to MD in the spring!
Glad to see another Celica nearby! -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 3, 2013 - 8:57 AM
Got the car "started" new years eve.
It knocked it self out of timing after running for a minute. While re-timing, looked under the car and saw fresh oil dripping, seems to have sprung a leak on the trans side of the oil pan after building some oil pressure. Got annoyed and closed up shop till I come back to PA next week to fix it. Exhaust has to get pushed off till early February too. Here are a couple things I got a couple months back 15lb braille! ![]() pretty arp nuts to replace the old rusty ones
Jan 3, 2013 - 3:14 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
nice. i'd relocate that battery to the glove box...
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
Jan 3, 2013 - 4:31 PM
then where would you put your spare zipties, extra tools, and ham sandwich?
Jan 3, 2013 - 7:04 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) |
...under armrest or CleanBox
-------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
Jan 15, 2013 - 7:39 PM
...under armrest or CleanBox what would I eat my cereal out of then? lol. this could on and on started getting in a couple parts for the exhaust re-fab ![]()
Jan 15, 2013 - 9:32 PM
a cat? what a looooseeerrrrrr
Jan 16, 2013 - 12:50 AM
started getting in a couple parts for the exhaust re-fab I must have missed this part.. why the refab? Still keeping the centered pipe tips right!? -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
Jan 16, 2013 - 5:26 PM
Its a highflow....does that make it ok? haha
The original design was flawed, I had always planned to get it re-fab'd professionally. Yup! Same exit! -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 16, 2013 - 5:58 PM
ok, ok, that's not as bad haha
Jan 21, 2013 - 8:21 PM
Got a set of APEXi GT spec front rotors.
Took them apart to possibly re-anodize the hats and re-finish the rotors, then safety wire the hat bolts upon reassembly. Along with those are the ST205 front and rear calipers i have apart for a rebuild and powder coat. Also have the ST205 rear rotors. The car should be out of the garage in 3 weeks, and taken to the fab shop for exhaust while the calipers get dropped off for a PC
This post has been edited by Tigawoods: Jan 21, 2013 - 8:22 PM -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 22, 2013 - 7:24 PM
ooooo two piece....niiiiice!
Jan 23, 2013 - 6:49 AM
Light weight goodness!
I had forgotten I took a pic of the TRD lsd before the install ![]()
This post has been edited by Tigawoods: Aug 14, 2013 - 7:32 AM -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 23, 2013 - 11:57 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
look at this guy ova heree! lol
doing big things looks good man This post has been edited by Ted95: Jan 23, 2013 - 11:59 AM -------------------- st205 powered ss3 coupe
| Lo-Fi Version | Time is now: September 21st, 2026 - 7:53 AM |
