Mar 21, 2009 - 9:07 PM
Enthusiast ![]() Joined Feb 6, '09 From Lexington, KY Currently Offline Reputation: 3 (100%) |
So last week I decided to switch the lugs on my rims, seeing that they were a list rusty, and while I was I doing this, I noticed that my brake lights were out of sync/out of line...
Considering I'm never behind my car when it's being driven, I guess this makes sense to not notice this. It may help if I show some pictures of what I'm trying to describe: 1). Here's a representation of what my car's taillights look like when the headlights are on in the front ![]() 2). Here's what they look when I have my brake lights on ![]() With that said, this is probably an easy solution to fix, but I wanted to make sure that there weren't any major do's/don't's to wiring the brake lights/taillights, such as complications with the housings or the resistors/inhibitors. I've scrolled through some of the Celica pics here on 6Gs and I haven't found a good representation of what the taillights should look like when the brakes are on, so I've put together some more pictures of possible brake light options. Could you guys point me in the right direction as to how I should fix this problem, as well as how they should look like? A). All Lights (I'd pick this one if it's possible) ![]() B). Outer Lights ![]() C). Inner Lights ![]() Soon, I plan on switching out the bulbs with LEDs, like these: http://www.eautoworks.com/product-Led-33240.htm and eventually some JDM housings, but in the meantime, I'd like to fix this little brake light issue. Thanks in advance, -Miles This post has been edited by Celiquick: Mar 21, 2009 - 9:18 PM -------------------- ---------------------------------------------------------------------------------------------------------------------------------------------------
Celiquick '97 Celica ST "Really" Limited Edition ![]() "I thought you always wanted an all-wheel drive, turbo-charged, Evo-eating machine sitting in your backyard.....who wouldn't?!?" Celica FS/Part-out |
Mar 21, 2009 - 9:24 PM
Enthusiast ![]() Joined Mar 3, '09 From Tampa, Florida Currently Offline Reputation: 0 (0%) |
Honestly, I'm not gonna lie, I have a similar problem with my brakes/tails. The first problem I have is that one of my tails is out. I got pulled over for it. Got a warning. Annoying as hell. The problem I had is that I had recently, maybe a week or two before, replaced the bulb. I'm thinking that might be a loose wire. The other problem I have is my brake lights alternate when I apply the pedal. One time the left will activate then the right.... never both at once. I have no idea what would cause this. Obviously the bulbs are fine. I'm thinking loose wires.
Mar 21, 2009 - 9:32 PM
Enthusiast ![]() ![]() ![]() Joined Feb 14, '09 From Mid West Currently Offline Reputation: 7 (100%) |
Honestly, I'm not gonna lie, I have a similar problem with my brakes/tails. The first problem I have is that one of my tails is out. I got pulled over for it. Got a warning. Annoying as hell. The problem I had is that I had recently, maybe a week or two before, replaced the bulb. I'm thinking that might be a loose wire. The other problem I have is my brake lights alternate when I apply the pedal. One time the left will activate then the right.... never both at once. I have no idea what would cause this. Obviously the bulbs are fine. I'm thinking loose wires. Wow! Sorry about the probs!! But anyway,thanks for the headsup! I'll check mine 2morrow--I had 2 replace my right tail light assembly due to a meeting w/a tree on the ice!! |
Mar 22, 2009 - 11:03 PM
Enthusiast ![]() Joined Oct 2, '08 From New Zealand Currently Offline Reputation: 0 (0%) |
As with all Electrical problems check your ground wire 1st and 2nd and 3rd.
My tail light would wink in rotation (Break, indicator, break, indicator) because of a rusted ground wire. My Amp tried to get it's earth through my Head unit beacause of a bad Earth..... So the best advice is CHECK YOUR GROUND WIRES.... -------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
![]() ~ signature made by jaws4god ~ Have a look at my thread for updates on my progress. "http://www.6gc.net/forums/index.php?showtopic=63338&hl=0" |
Mar 23, 2009 - 6:17 PM
I don't really get what you are talking about in your pictures. Could you get some real pictures of what you are talking about? Because it sounds to me like the second element in a couple of your bulbs have simply burned out. It would be a $5 fix.
Mar 23, 2009 - 7:43 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
are the sockets in the correct position?
Mar 25, 2009 - 11:10 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
in my celi all four light with the brakes, so i assume you just have to replace your bulbs
Mar 26, 2009 - 3:14 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
I'll also chime in with the bulb suggestion. Keep in mind the bulbs have two elements, so while they may light up under one condition, they don't under another.
Mar 26, 2009 - 6:57 AM
^ thats what I thought for example, bulbs have two filaments like ours. when driving reg. it has a dim light on both sides, keep in mind there are 2 bulbs on each side. if 1 bulb filament (for braking) is burnt out and when you brake it won't light up. To me your just on with the headlights looks normal, when you brake it doesn't. I think you need to replace the bulb with the bad filaments on both sides. Thats what it looks like - looks like an easy fix, pull out both your taillights and compare the good bulbs with the bad bulbs. 1 filament is for parking/driving and the other is for braking. You will need to replace the left outer and the right inner bulbs.
This post has been edited by trdproven: Mar 26, 2009 - 6:58 AM -------------------- 94 Celica GT
| Lo-Fi Version | Time is now: August 24th, 2026 - 11:18 AM |
