Mar 27, 2009 - 8:39 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 5, '06 From San Luis AZ Currently Offline Reputation: 4 (100%) |
hi guys
i was trying to change the valve and the head gasket but the wire broke and the tip of the wire got stuck on the tip of the spark plug and i just can't take it out! and for my luck the valve gasket that they gave me is not for my car!!! any clues?? thanks also this thing broke but i dont know what it is called,, can someone tell me? ![]() it goes from the head cover to the carburetor! This post has been edited by joehernandez: Mar 28, 2009 - 1:15 AM -------------------- ![]() |
Mar 28, 2009 - 12:30 PM
![]() Enthusiast ![]() ![]() Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
um ok, how much of the wire broke off? u could just use a pair of long needle nose pliers and pull the wire off the plug, or get an extra deep 5/8s socket and just take the whole plug out. and as far as what that other thing that broke is im not sure, cnt really see in the picture, and our cars dnt have carburatoers. so... where does it actually go to?
-------------------- Lift Addict!! ^_^
Mar 28, 2009 - 1:18 PM
carb lol...
my vote is what he thinks is a carb is actually the throttle body. and you need to use LONG needle nose pliers to remove the excess wire. |
Mar 28, 2009 - 2:12 PM
hahahaha thanks guys,,
i meant throttle body!!! hahaha you see im Latin so i don't really know what are they called here haha.. well i figured out it is a PCV HOSE, but i already got it,, about the needle nose pliers, i haven't found any long enough,,, but i will keep looking,,, bad news but my ngk spark plug wires wont arrive until Tuesday or Wednesday -------------------- ![]() |
Mar 28, 2009 - 3:42 PM
well if you have a harbor freight near you, or an autoparts store, or even home depot should have those pliers
Mar 31, 2009 - 10:50 AM
Enthusiast ![]() ![]() ![]() Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) |
I actually had that happen to me a few years ago. is it just the thin metal band that was inside of the spark plug wires? I think I just took out the plug with a spark plug socket.
-------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Mar 31, 2009 - 11:50 AM
Enthusiast ![]() ![]() Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
well something like that happened to me, the Core from the Spark plug wire broke off and got stuck on top of the Spark Plug which I couldnt take out cuz the core kept my socket from reaching it, I just used some very long Needle Nose Pliers, but they had to be thin I tried using nother pair which had a slightly fatter base and it wouldnt open in the socket hole. You can try that.
| Lo-Fi Version | Time is now: May 20th, 2026 - 9:02 AM |
