Mar 28, 2009 - 5:42 PM
Im getting a thumping noise on deceleration only. It sounds very similar to the noise you would hear if you had a flat tire. It is mostly noticeable where decelerating in 3rd gear, right around 2,000 rpm. Its hard to pinpoint if its coming from the left or the right side... kind of sounds like the clutch/trans right in the center of the front of the car.
Anyone deal with something similar to this? My original diagnosis was that my axle that had been leaking grease was the cause of the noise, but I swapped the axle out for a brand new one (needed to be done sooner or later anyway). but the thumping persists. Any ideas? -------------------- 15PSI - 30MPG - Megasquirt Tuned
lagos Thumping noise Mar 28, 2009 - 5:42 PM
95celgt this one time i felt that in my old St, and it tur... Mar 28, 2009 - 7:30 PM
lagos Motor mounts all have poly inserts in them and loo... Mar 29, 2009 - 2:54 AM
sillica i get a thud in my rear left wheel when i get down... Mar 31, 2009 - 5:31 AM
lagos Can someone with a manual gt do me a favor?
Can y... Mar 31, 2009 - 1:59 PM
95celgt ill do it when i go home in a bit, but IRRC, the o... Apr 1, 2009 - 11:34 AM
lagos cool, let me know. Apr 1, 2009 - 3:35 PM
95celgt ok just checked, its completely inaccessable from ... Apr 1, 2009 - 5:02 PM
lagos Thanks for checking.
I guess what I really need t... Apr 1, 2009 - 7:37 PM
95celgt Acually, when i was removing the old (first) axle,... Apr 2, 2009 - 10:08 AM
Jeunesse I had this very same problem, but I hear thumping ... Apr 2, 2009 - 10:13 AM
lagos QUOTE (95celgt @ Apr 2, 2009 - 11:08... Apr 2, 2009 - 9:28 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 9:59 AM |
