Apr 1, 2009 - 11:46 AM
Enthusiast ![]() ![]() Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
So long story short;
went to swap out throttle bodies and the plug from the harness to the Idle control valve had been tampered with by the previous owner and the wires pulled out of the clip. So my issue lies in the fact that now I do not know which wire goes into which port on the plug. I need to know so I can re-wire it. My question, and the favor I need doing is just for someone to take a peak and let me know which colors to to what port. The ports are numbered and the wires are colored (i mean multicolored...im not a racist) so it shouldn't be too difficult. Thank you in advance -------------------- ![]() The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Apr 2, 2009 - 11:15 AM
guess not huh?
Apr 2, 2009 - 11:42 AM
![]() hope that helps Nate, give me a call if you need anything -------------------- |
Apr 3, 2009 - 4:34 PM
My question, and the favor I need doing is just for someone to take a peak and let me know which colors to to what port. The ports are numbered and the wires are colored (i mean multicolored...im not a racist) so it shouldn't be too difficult. Thank you in advance -------------------- ![]() |
Apr 6, 2009 - 2:41 PM
as soon as the weather clears up I will b heading out to do this up.
for now i will just drive a stalling celi... -------------------- ![]() The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
| Lo-Fi Version | Time is now: August 28th, 2026 - 7:53 AM |
