> Hooking up Fog Lights, Whats the best way to hook up fog lights on an st
post Apr 1, 2009 - 10:36 PM
maserati21
Joined Apr 30, '08
From Buffalo
Hey guys and girls,
I was thinking about getting fog lights but , i was wondering what the best way was to hook them up (switch and wiring) etc..Always can i get them converted to HIDs..any help much appreciated..
Replies (1 - 4)
post Apr 3, 2009 - 3:44 AM
Legit94GT
Joined Feb 6, '08
From Oregon
there is no best way.
You can wire it to a seperated switch or...
***correct me if i am wrong*** take the steering column off of a celi that came from the factory with fog lights and therefore has it wired. I am not sure if those come factory wired to turn on with the Low's or if you have to pull on the knob to get them to turn on seperately.
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Apr 3, 2009 - 5:58 AM
trdproven
Joined Aug 2, '05
From Guam
you have to get the turn signal switch with the fog or run it direct to a switch. I ran mine direct but I do have a fuse still. There is a sticky that martin did.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 6, 2009 - 7:23 PM
costa
Joined Nov 6, '08
From locust grove, va
i just wired them to my excisting headlight wires. you get a ticket if you have them on if your headlights arent on anyway. Ground them seperatly and take the hot wire from one of your headlights and them put a bigger fuse in for the headlights and your good to go. message me back if you have any questions.
post Apr 12, 2009 - 12:32 AM
razor7
Joined Jul 9, '08
From California
Wow,
You guys did complicated work. I wired mine into my running lights. If you turn the column once (just driving lights, no headlights) you'll get fogs, 2 turns forward will be fogs with lows, then push the whole column forward to fogs, lows, and highs.
Just use a millimeter to be sure which wires to splice into. There's 3 total, and they change colors for left and right. I think it was the left and center wire, but double check with a millimeter to be absolutely sure.
-TC
Live your life for yourself. Don't hold back for anything or anyone.
Lo-Fi Version Time is now: July 30th, 2026 - 2:24 PM
