Apr 3, 2009 - 10:57 AM
![]() Enthusiast ![]() Joined Jan 14, '07 From Little Rock, AR Currently Offline Reputation: 0 (0%) |
well, my car has been sitting for half a year. my dad and i just got it running again yesterday after completely rebuilding the motor because one of the rings spun on the arm of the piston. now, whenever i turn on the air, it kills my rpms and tries to kill the car completely. any ideas of what the problem might be?
Apr 3, 2009 - 2:05 PM
Enthusiast ![]() Joined Aug 28, '08 From Woolwich, Maine Currently Offline Reputation: 0 (0%) |
the first thing i would do is test the charging system, make sure that alternator is putting out the right voltage.
Apr 3, 2009 - 3:03 PM
When you turn on the air, is your air conditioner on?
You absolutely want to test the alternator and make sure it's putting out the correct voltage and continuity -------------------- ![]() |
Apr 24, 2009 - 2:05 PM
if i turn it on, it gets cold as hell like normal, it's just that my rpms drop. if i didn't have the right voltage wouldn't my subs or the car itself have already drained the battery?
Apr 24, 2009 - 2:35 PM
![]() Enthusiast ![]() ![]() Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
a/c is more constant draw though, and what kind of sytem are u running? prob. time for a alt, and deep cycle battery upgrade.
-------------------- Lift Addict!! ^_^
Apr 27, 2009 - 1:49 AM
its just two 12' mtx 800watt each. it never did this before i rebuilt it though.
This post has been edited by cwlevie21: Apr 27, 2009 - 1:49 AM -------------------- ![]() |
Apr 27, 2009 - 1:53 AM
either way, id atleast test the alternator, and have the battery tested to see if it has a bad cell, or if it even has the cca required.
Apr 27, 2009 - 2:44 AM
Enthusiast ![]() ![]() ![]() Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
Does this happen at idle in neutral only, while driving, or when?
Hold a steady 2000 rpm in neutral and turn the AC on without moving your foot. What happens? |
Apr 27, 2009 - 5:46 AM
somthing is up with your a/c idle up valve.
its either not working, or not hooked up properly. -------------------- Former Team 5SFTE pro member ;)
Apr 27, 2009 - 12:02 PM
somthing is up with your a/c idle up valve. its either not working, or not hooked up properly. X2 -------------------- Lift Addict!! ^_^
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:46 AM |
