Apr 3, 2009 - 7:12 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Ok, so I recently changed my plugs and wires. Cleaned what I could on the Intake manifold and the TB, as well as re-oiled my air filter. I was having a real rough idle after I did the InManifold and TB, but the plugs and wires kinda fixed that. But I still had excessive vibration at idle, but none during acceleration. Two days ago I run this road and pushed it kinda hard (I was having some fun), the next day I go to start up and everything seems fine, vibrations at idle almost all but ceased. When I pressed the pedal I got what sounds like I have a mini muffler up in my engine bay. Dont get me wrong, it sounds kinda cool just crusing under 2K (anything above that, it sounds normal). As I have never had this problem before, figured someone here might be able to figure this out.
Thanks! |
Spider77 More engine noise Apr 3, 2009 - 7:12 PM
xrav22 QUOTE (Spider77 @ Apr 3, 2009 - 7:12... Apr 3, 2009 - 7:53 PM
Spider77 Yeah, Im gonna go out and look at it today to see ... Apr 5, 2009 - 1:00 PM
Akirad1 maybe a leak in your exhaust sytem hopefully not Apr 5, 2009 - 1:14 PM
Ryouxrs can u post up a vid. clip of the noise? that'l... Apr 5, 2009 - 1:37 PM
Spider77 I was thinking exhaust...hopefully if it is its ju... Apr 5, 2009 - 1:57 PM
Akirad1 aight man if you need any help when you get it fig... Apr 5, 2009 - 2:03 PM
Spider77 Ok, so I had one that was in the engine bay, but d... Apr 5, 2009 - 3:03 PM
Bitter sounds like a small exhaust leak.
with the engine... Apr 5, 2009 - 3:27 PM
Spider77 As in cram my tailpipe with a snake? Ok got that,... Apr 5, 2009 - 3:42 PM
Ryouxrs remove the fuel pump relay, and unplug the 2 distr... Apr 5, 2009 - 5:13 PM
Spider77 Yeah, did that. Stripped off the heat shield and ... Apr 5, 2009 - 5:48 PM
Ryouxrs just double check the intake manifold with carb cl... Apr 5, 2009 - 5:59 PM
Spider77 Well havent seen any ash yet. I was hoping to see... Apr 5, 2009 - 6:07 PM
Galcobar Check that your air filter box is properly locked ... Apr 6, 2009 - 5:45 PM
Spider77 No box, Injen. Apr 6, 2009 - 6:15 PM
Ryouxrs any updates on the noise? Apr 7, 2009 - 1:18 AM
Spider77 Not yet, yesterday was too cold, and spent most th... Apr 7, 2009 - 5:19 PM
Spider77 Ok, so its totally the flex pipe....Im surprised t... Apr 7, 2009 - 6:26 PM
Ryouxrs no idea, u could take it to a local exhaust shop, ... Apr 8, 2009 - 1:34 AM
Spider77 Yeah, Im going in in about a week or so to get my ... Apr 8, 2009 - 7:07 PM
Spider77 OK, so its been a while since Ive worked on the ce... Apr 25, 2009 - 4:50 PM
Ryouxrs not unless u hit a sensor with it, its just very c... Apr 25, 2009 - 7:02 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 27th, 2026 - 4:23 AM |
