> Timing belt shreddng
post Apr 5, 2009 - 7:07 PM
turboman23
Joined Jan 25, '08
From Topeka, KS
Hello,
I just put a new timing belt on because my last one ( a few months old) shredded.
It now looks like my new one is doing the same. It looks like it is rubbing against the block and badly against pump. I made sure to try and center it on the pully's when I installed both of them.
Any ideas why this is happening?
Thanks
1st car- 1994 Celica GT 2.2L 5s-fe SOLD
2nd car- 1995 Celica ST 2.0L 3s-gte SOLD
Current car- 1996 Z28 Camaro 5.7L LT1
post Apr 5, 2009 - 9:33 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
tentioner on correct? if its not sitting flush with the block it'll push the belt one way.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Apr 7, 2009 - 5:52 PM
turboman23
Joined Jan 25, '08
From Topeka, KS
QUOTE (Cuts_the_Pilot @ Apr 5, 2009 - 9:33 PM) *
We noticed tonight that the belt was moving as it went around the tensioner. It just bolts to the block, or am I missing something that would cause it not to set flush?
post Apr 7, 2009 - 6:01 PM
bmj67
Joined Oct 23, '08
there is an alignment pin for the tensioner if you dont have it in the hole on the tensioner it will cause it to sit crooked.
post Apr 7, 2009 - 6:27 PM
Cuts_the_Pilot
Joined Dec 15, '02
yeah it bolts to the block but if your not careful it can sit a bit crooked.
if the belt is moving then something is make it move obviously. Check the idler too.
post Apr 8, 2009 - 12:25 AM
azian_advanced
Joined Apr 18, '05
From Calgary
you may have warped pulleys (from age and high mileage) and may need to replace them.
post Apr 9, 2009 - 9:20 AM
QUOTE (azian_advanced @ Apr 8, 2009 - 12:25 AM) *
yup, one of your pullies/idlers is bent.
post Apr 9, 2009 - 8:15 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
I've seen this happen once before on a 3SGTE. There is a thick washer behind the tensioner pulley (between the pulley and the block) that was misplaced. Without it there, the belt kept pulling in towards the engine and shredding itself.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
Lo-Fi Version Time is now: August 23rd, 2026 - 11:22 AM
