> Projector Retro, It FINALLY stopped raining for 2 consecutive days!
post Apr 6, 2009 - 3:59 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
So I've been working towards this for a while, and I finally got the time and a dry weekend to complete my projector retrofit. This is my first time doing anything like this, so go easy on me! I used Rayme's lenses and his stickied How-To write-up for guidance. I took pix along the way sort of as an appendix to his write-up for those of us who do better with detailed visuals. I put clear lenses on all 4 headlights, but the pix below specifically pertain to the low beams, as the high beams is self explanatory.
Before:
Lense Removed from one of the low beams:
"Exploded view" of the components that make up the low beam internals:
Tiny stainless bowl of vegetable dip mix (!) and bathtub faucet ring for shroud and bezel use:
Cut out the bottom of the bowl for the lens to fit through:
Cut out the reflector to fit the back of the projector through - no turning back at this point!
Test fitting the projector. When I marked up the reflector to mount the projector, I removed the lens from the projector so I could make sure the cutoff shield was level. Then I test fit the projector in the reflector only, to make sure it bolted in correctly. Once I was sure that it was correct, I mounted the reflector back into the headlight bucket, tightened it in, and then drilled the projector mounting holes all the way through. By doing this, I'm able to adjust the alignment of the projector itself within the reflector.
Test-fitting the shroud I made. I had to cut a notch at the top of it to allow it to recess into the reflector without the glare shield mounting point obstructing it.
I also bent the bottom part of the shroud up to flatten it down some. The bent part doesn't show once it's in, but it allows the shroud to fit better into the reflector unit. I probably could have just cut this part out, but I wasn't sure how much of that would show, and I wanted to keep it as finished looking as possible.
Test fitting it over the mounted projector (still without the lens on it, so I didn't risk chipping or scratching the glass lens:
After.
This morning I learned that JB weld was a bad idea, as it doesn't bond metal to plastic well at all. Note the top part of the shroud on the passenger side. Now my celi has a lazy eye. Bummer. If I get home in time tonight, I will take it apart and figure out a plan B. It will probably involve using the mounting point where the glare shield went to screw the shroud to. The screw is small, and will probably not show at all, but we'll see.
Close-up of the driver's side. Other than the issue with the passenger shroud, I'm really happy with how they came out. Once I get the passenger side fixed, I will aim them and take night shots of the cutoff. It looks really good though and has nice color banding at the top.
- GriffGirl   Projector Retro   Apr 6, 2009 - 3:59 PM
- - d0w0rkS0n   wow! that looks so sexy!! great job...   Apr 6, 2009 - 4:10 PM
- - 96bluevert   nice work! Props for originallity.   Apr 6, 2009 - 4:17 PM
- - manphibian   Great Job!!!! I think you should ...   Apr 6, 2009 - 4:25 PM
- - DEATH   Holy fcukin sh*t - nice job Griffy Now make me som...   Apr 6, 2009 - 4:42 PM
- - njccmd2002   rivets, that bonds well   Apr 6, 2009 - 4:44 PM
- - GriffGirl   Yeah, I was thinking rivets QUOTE (DEATH @ A...   Apr 6, 2009 - 5:03 PM
|- - DEATH   QUOTE (GriffGirl @ Apr 6, 2009 - 5:0...   Apr 6, 2009 - 5:25 PM
|- - razor7   QUOTE (GriffGirl @ Apr 6, 2009 - 6:0...   Apr 11, 2009 - 11:40 PM
|- - GriffGirl   QUOTE (razor7 @ Apr 11, 2009 - 9:40 ...   Apr 13, 2009 - 11:54 AM
|- - razor7   QUOTE (GriffGirl @ Apr 13, 2009 - 12...   Apr 13, 2009 - 7:19 PM
- - dustin15brown   they look good, how's the beam pattern? Also, ...   Apr 6, 2009 - 5:09 PM
|- - GriffGirl   QUOTE (dustin15brown @ Apr 6, 2009 - 3...   Apr 6, 2009 - 5:40 PM
|- - richee3   QUOTE (GriffGirl @ Apr 6, 2009 - 5:4...   Apr 6, 2009 - 6:08 PM
|- - dustin15brown   QUOTE (GriffGirl @ Apr 6, 2009 - 6:4...   Apr 6, 2009 - 10:43 PM
|- - GriffGirl   QUOTE (dustin15brown @ Apr 6, 2009 - 8...   Apr 7, 2009 - 11:50 AM
- - xs94st   Awesome work griff..good sense of ingenuity =) A+...   Apr 6, 2009 - 11:33 PM
- - dustin15brown   I would ASSUME so, but don't quote me on that   Apr 7, 2009 - 1:26 PM
- - GriffGirl   When you molded the fiberglass to make the shrouds...   Apr 7, 2009 - 2:16 PM
- - SveNRG   Respect for your work and originality. They look m...   Apr 7, 2009 - 3:57 PM
|- - GriffGirl   QUOTE (SveNRG @ Apr 7, 2009 - 1:57 P...   Apr 9, 2009 - 5:14 PM
- - trdproven   looks good except for the lazy eye. Just my 2 cen...   Apr 9, 2009 - 9:46 PM
- - Rayme   Nice one girl, you made your research well !   Apr 10, 2009 - 6:37 AM
- - Lil-Joe101   Kinda reminds me of Number Johnny5 from Short circ...   Apr 10, 2009 - 6:47 AM
|- - d0w0rkS0n   QUOTE (Lil-Joe101 @ Apr 10, 2009 - ...   Apr 10, 2009 - 9:32 AM
- - GriffGirl   Totally!   Apr 10, 2009 - 11:18 AM
- - malpaso   that's totally cool making own projectors... t...   Apr 13, 2009 - 12:08 PM
- - KAOS   Nice work Michelle... Or in the words of Johnny ...   Apr 13, 2009 - 4:47 PM
- - GriffGirl   It's supposed to be warm and sunny this weeken...   Apr 14, 2009 - 5:10 PM
- - vile_v   you should maybe to try painted all the shiny silv...   Apr 19, 2009 - 6:58 PM
|- - ra65_22re   QUOTE (vile_v @ Apr 19, 2009 - 4:58 ...   Apr 19, 2009 - 7:47 PM
- - GriffGirl   Well that's actually what I wound up doing whe...   Apr 21, 2009 - 5:21 PM
|- - razor7   QUOTE (GriffGirl @ Apr 21, 2009 - 5...   Apr 22, 2009 - 4:34 PM
- - 95CelicaST   You should really put some drift ties on that crac...   Apr 21, 2009 - 7:32 PM
|- - GriffGirl   QUOTE (95CelicaST @ Apr 21, 2009 - 5...   Apr 22, 2009 - 10:54 AM
|- - 96bluevert   QUOTE (GriffGirl @ Apr 22, 2009 - 8...   Apr 22, 2009 - 1:29 PM
|- - KAOS   QUOTE (96bluevert @ Apr 22, 2009 - 12...   Apr 22, 2009 - 1:33 PM
- - 96bluevert   good work... I think they are fine as is.   Apr 21, 2009 - 11:54 PM
- - GriffGirl   Where'd you get the shrouds? I'm at the po...   Apr 22, 2009 - 5:16 PM
- - razor7   QUOTE (GriffGirl @ Apr 22, 2009 - 6...   Apr 27, 2009 - 1:49 AM
Lo-Fi Version Time is now: September 13th, 2026 - 2:35 AM
