> How easy?, In Dash White Guages
post Apr 7, 2009 - 8:51 PM
6G96GT
Joined Jan 20, '08
From East Coast
So I want to install a factory-looking and high quality set of white face guages for my dash. Any recommendations and is it an easy install??
Replies (1 - 18)
post Apr 8, 2009 - 2:53 AM
eggman40
Joined Aug 17, '04
From California
QUOTE (6G96GT @ Apr 7, 2009 - 5:51 PM) *
are you referring to the actual gauge cluster? or adding in after market gauges that look factory? I have some Defi gauges above my radio if you see the pic in my profile.
post Apr 8, 2009 - 2:04 PM
6G96GT
Joined Jan 20, '08
From East Coast
That looks good but I'm looking for the cluster guage set.
post Apr 8, 2009 - 3:32 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
I have one , white faces that glows greenish/blue. 25 shipped to ur door.
post Apr 10, 2009 - 3:22 PM
6G96GT
Joined Jan 20, '08
From East Coast
What kind and where did you get it and was it hard to install?
post Apr 10, 2009 - 7:53 PM
razor7
Joined Jul 9, '08
From California
Installation is pretty easy.
Screw off of the panel below the steering wheel, then you'll find 4 screws holding on the plastic housing of the gauge cluster (2 on the bottom left and right corners, and 2 under the sun visor). Then it should just pull out. There's 2 or 3 wire clusters to disconnect. From there the housing has some screws holding the plastic cover. You can slide the covers over the old needles and pull them tight. I would recommend putting a tiny bit of glue on the back.
Be sure to mark where your gas needle is sitting (or give it a full tank before doing this). Since it doesn't reset, if you bump it, it'll be off (which was the ONE thing I did wrong on mine...).
The gas and temp needles can pop off if you pry up the sides. This is the only way to get on those covers (if you do them at all).
I'm sure I'm missing a couple of screws, but there aren't many in total. Once you start, you'll easily spot the next ones that you need to take out. Got mine out first try, and back together perfectly the first try.
Also, the actual bulbs behind the cluster have a green film on them. If you take these off, your needles will glow a nice orange color. Otherwise your needles will be the standard green.
-TC
Live your life for yourself. Don't hold back for anything or anyone.
post Apr 11, 2009 - 2:28 PM
mneal2_92788
Joined Nov 7, '06
The one I have slide on all the guages over the needle, no taking them off at all. Super easy to install.
post Apr 12, 2009 - 10:12 AM
DO NOT TAKE YOUR NEEDLES OFF!!!
Doing so will screw up your gauge cluster. The overlays slide OVER the needle.
post Apr 12, 2009 - 11:07 AM
mneal2_92788
Joined Nov 7, '06
QUOTE (lagos @ Apr 12, 2009 - 11:12 AM) *
Those are the ones I have
post Apr 12, 2009 - 1:19 PM
razor7
Joined Jul 9, '08
From California
QUOTE (lagos @ Apr 12, 2009 - 10:12 AM) *
It's easy to pop off your gas and temp needles, those will just pop back on and so long as you mark your gas needle's spot, you won't have any issues.
Don't take off the RPM and Speedo needles, you can slide over those ones.
-TC
post Apr 17, 2009 - 4:25 PM
6G96GT
Joined Jan 20, '08
From East Coast
thanks for the info guys and the warnings too. Definitely going to do this, this weekend.
post Apr 24, 2009 - 9:24 AM
zoik
Joined Aug 28, '07
From france
ive replaced the oem bulbs by ones of the same stype but with leds on them, ill try to take some pictures later in the day.
post Apr 24, 2009 - 10:21 PM
6G96GT
Joined Jan 20, '08
From East Coast
didn't have the time to do it yet but what I'd like to see those pics when you get a chance zoik
post Apr 25, 2009 - 11:37 AM
zoik
Joined Aug 28, '07
From france
here!
the dash gauges
http://i77.photobucket.com/albums/j54/_zoik_/dash2.jpg
an overview of my interior
http://i77.photobucket.com/albums/j54/_zoik_/dash1.jpg
i haven't painted the needles, but one day, ill do it
This post has been edited by zoik: Apr 25, 2009 - 11:41 AM
post May 3, 2009 - 7:28 PM
6G96GT
Joined Jan 20, '08
From East Coast
very nice, I wouldn't even paint them.
post May 5, 2009 - 7:20 PM
6G96GT
Joined Jan 20, '08
From East Coast
Zoik, where did you get those and part number or type?
post May 6, 2009 - 2:58 PM
zoik
Joined Aug 28, '07
From france
hum, i got a replacement bulb made up with leds from a seller in ebay(the 6 leds one), ive received it fast and very- well packed, i give you the link to his shop
---> http://stores.ebay.fr/warden-jp2002
i think the bulb type is 194 for the gauges,so this one , but im not sure, i did this 6months ago, check it out :
http://cgi.ebay.com/ebaymotors/2pcs-168-19...32346QQtcZphoto
post May 6, 2009 - 3:59 PM
92-gt
Joined Jan 22, '09
From Bremen
Yes, you need 194 type bulbs. For the key ring light and ash tray light you need bulb type 74 IIRC.
post May 9, 2009 - 9:20 AM
6G96GT
Joined Jan 20, '08
From East Coast
thanks guys!
Lo-Fi Version Time is now: August 27th, 2026 - 11:51 AM
