> License PLate Garnish Rattle..., how do you keep yours from rattling?
post Apr 8, 2009 - 2:22 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
I had recently installed some foam rubber on the back of the license plate and put rubber washers on the plate bolts to stop rattling in the trunk area...
well that helped, but the garnish still rattled like no other. I took the lights off, got to the garnish and put foam rubber pieces on almost each of clips of the garnish and put a few strips on the piece itself. I thought this would work but it didn't fix the problem.
how have you guys coped with your garnish plate rattling?
mine is immensely loud.
Replies (1 - 4)
post Apr 8, 2009 - 9:32 AM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
i made a thread about this a while ago it has a few suggestions
http://www.6gc.net/forums/index.php?showto...&hl=license
post Apr 23, 2009 - 4:42 PM
petna
Joined Mar 2, '08
From Manchester - UK
I went for strategic placement of dynamat extreme and there is no rattle there now
www.celica-club.co.uk
My Garage
post May 6, 2009 - 4:31 PM
AnaXyd
Joined Jul 15, '08
From Norway
How do you remove the license plate garnish? I tried once, but I was to afraid to break it...
post May 7, 2009 - 7:08 AM
azian_advanced
Joined Apr 18, '05
From Calgary
-remove the rear-most hatch interior panel
-remove tail lights (3 10mm bolts holding it)
-remove 1 bolt on each end of the license plate bezel then pull outwards to unsnap the clips.
Lo-Fi Version Time is now: August 28th, 2026 - 4:06 AM
