Apr 11, 2009 - 11:42 PM
Enthusiast Joined Jan 26, '09 From massachusetts Currently Offline Reputation: 0 (0%) |
So heres the problem....
My gears grind. The clutch is good. Press in the clutch... to the floor, let off the gas... or vice versa... guess it depends on the driver... but either way... if i dont let the rpm's drop down low, the gears grind. doesnt matter what gear. doesnt matter if its up or down. only thing that matters is the rpm... if its higher they grind, if its low say below 2500 they don't. cant give an exact number cause whoever had the car before me put in new gauge faces and messed up all the needles... could it be a flywheel issue? shifter needs adjustment? fluid change? please help!!!!!! |
Apr 11, 2009 - 11:47 PM
so.... i think maybe this guy knows what my problem is... anyone know where i can get a heavy duty set of gears???
"take to reputable transmission shop to get it diagnosed and repaired. it sounds like the synchronizers are a problem there. and you may have metal in your fluid now that it's been grinding which will affect the rest of the transmission. if you are speed shifting as in racing, you are not doing your transmission any good. you probably don't have a transmission built to do that if it's the original factory tranny... meaning you did a major NO NO to your tranny and are tearing it up speed shifting when it isn't built for racing." |
Apr 12, 2009 - 3:23 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
Use Pennzoil Synchromax or Royal Purple Synchromesh.
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Apr 12, 2009 - 6:21 PM
![]() Enthusiast ![]() ![]() Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
Use Pennzoil Synchromax or Royal Purple Synchromesh. X2 on the fluid, but it does sound like a syncro problem -------------------- Lift Addict!! ^_^
Apr 18, 2009 - 10:33 PM
Enthusiast ![]() ![]() ![]() Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
Synchros shot. Rebuild time. Or learn to double-clutch.
As a test, have someone who is good at double-clutching drive the car. He/she should be able to shift without grinding. If they can't, I'm wrong. This post has been edited by dgbldr: Apr 18, 2009 - 10:37 PM |
Apr 21, 2009 - 11:30 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
Are you sure the clutch is good? I had a Mustang that showed pretty much the exact same symptoms, hard to shift, etc. Clutch was brand new, turned out the pressure plate was messed up by whoever installed it and wasn't allowing the clutch to disengage fully. I would at least see if you can adjust your pedal to make sure you are releasing the clutch fully.
Otherwise try Synchromesh fluid before you jump to conclusions about rebuilding or replacing the tranny, can at least give it some extended life. -------------------- 1999 Celica GT
Apr 22, 2009 - 2:14 AM
You can test for clutch dragging (not disengaging fully). Start in neutral. Then pedal to the floor, put in gear. If it's dragging, engine rpm will go down.
| Lo-Fi Version | Time is now: July 31st, 2026 - 12:39 PM |
