Apr 12, 2009 - 8:54 PM
![]() Enthusiast ![]() Joined Oct 19, '07 From Québec, Canada Currently Offline Reputation: 0 (0%) |
Here is my latest modz, a triple gauge kit molded at the top of my head unit. I wanted this kit to be as close as "factory installed" as possible. I ask a freind to mold it to rough, and I finished it my self, including final adjusments and finish. Here's what it looks like:
![]() ![]() ![]() ![]() For the "low gloss" finish, I've used the semi-gloss Krylon paint for plastic, and for the final molding, the famous Mighty Putty as seen on tv Let me know what u think -------------------- |
Apr 13, 2009 - 12:33 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
that looks great.. can you make me one?
Apr 13, 2009 - 2:06 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 10, '06 From Mozambique, Africa Currently Offline Reputation: 8 (100%) |
Nice and clean fit!
-------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Apr 13, 2009 - 2:13 AM
Enthusiast ![]() ![]() ![]() Joined Feb 6, '08 From Oregon Currently Offline Reputation: 8 (100%) |
that looks great:) nice work, be expected to be asked to make more, many many more lol
-------------------- 1 JL 1,000/1v2
2 JL 12" W6v2 2 Focal 6.5 component 165a1 Kenwood DDX512 head unit Running 142.6db with the back seat up:) |
Apr 13, 2009 - 5:38 AM
Enthusiast ![]() ![]() Joined Mar 23, '08 From Denmark Currently Offline Reputation: 10 (100%) |
Looks very nice mate. OEM style ;-)
-------------------- [font=CELICA FOREVER][/font]
Apr 13, 2009 - 10:58 AM
Thank u guyz
If you want to make one of your own, be sure tu use 1½" gauges, otherwise it won't fit into the second din! Here's some more pics to help understand the process: ![]() ![]() ![]() ![]() This is when it was ready to be painted to final finish: ![]() And for the gauges connections, simply refer to installation guide provided with the gauge kit, be advised that you'll need some extra fittings and t's if you want to keep your instrument cluster 100% functional. Because this gauge kit is mechanical and not electrical, oil must be bring to the oil pressure gauge itself, and cooling temp sensor is a capilary type (tube filled with ether) to conduct heat. For the voltmeter, I simply connect it to my existing head unit power and ground wires. For lightning, I connected it once again to my head unit lights-in wire. Time estimated for molding: 20 hours of work, for installation: 3-4 hours. A hole week of work if you include drying times of the different steps involded. Total cost estimated: 40$ for the gauge kit, 50$-60$ of material for molding This gauges kit from Equus is black faced gauges, but they are also available in white faced gauges. The bulbs used in this kit are #161, widely available. You can have them painted to match your lighting theme, if needed. So who's next? This post has been edited by HorseHead: Apr 13, 2009 - 11:03 AM -------------------- |
Apr 13, 2009 - 11:09 AM
I've seen some gauges kit installed in the air duct holes. Then you can use larger gauges if you don't need the air duct.
Inside a MR-2 MKII JDM: ![]() ![]() This car belongs to my friend----> http://mr2phoenix.monchar.com/ -------------------- |
Apr 15, 2009 - 3:18 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
crazy nice! job well done!
-bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Apr 18, 2009 - 2:12 AM
Thanx bboy
However, I just learned today that the mechanical oil pressure gauge is not street legal and in case of accident this can leads to issues with your insurance company, especially if fire is involved. So I would not recommand the use/installation of this kind of gauge. -------------------- |
Apr 18, 2009 - 12:06 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
I didn't even know you can buy a mechanical oil pressure gauge.
If you want to repaint it, look into what is called plasti dip. It gives a nice textured look without the gloss. ![]() -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 23, 2009 - 4:39 PM
Enthusiast ![]() Joined Mar 2, '08 From Manchester - UK Currently Offline Reputation: 0 (0%) |
Neat install
-------------------- www.celica-club.co.uk
My Garage |
Apr 23, 2009 - 5:30 PM
Enthusiast ![]() ![]() ![]() Joined May 10, '07 From Lubbock, Texas Currently Offline Reputation: 2 (100%) |
u should make a HOW TO.........great look
-------------------- ![]() feedback feedback If I buy or sale please leave me feedback...thanks cheap, quick, reliable, pick two I treat my 6gc better then my own woman |
Apr 23, 2009 - 5:34 PM
just a thought, you say that you've connected to the stereo power, isn't this a regulated 12V supply?? so you will not actually be seeing what the true battery voltage is??
I ran a power feed from the batt to my volt gauge, and used the ignition lead to the stereo as the 'switch' for the gauges. This then gives the actual battery volts. Have you noticed this or is it not a regulated supply?? -------------------- www.celica-club.co.uk
My Garage |
Apr 23, 2009 - 6:47 PM
Enthusiast ![]() ![]() Joined Mar 3, '08 From New Zealand Currently Offline Reputation: 1 (100%) |
man that looks great!!!
-------------------- ![]() _______________May COTM 2011_______________ |
Apr 23, 2009 - 8:59 PM
just a thought, you say that you've connected to the stereo power, isn't this a regulated 12V supply?? so you will not actually be seeing what the true battery voltage is?? I ran a power feed from the batt to my volt gauge, and used the ignition lead to the stereo as the 'switch' for the gauges. This then gives the actual battery volts. Have you noticed this or is it not a regulated supply?? No it's not regulated, I've take my readings with a multimeter right at the battery before installing my gauge and I had the exact same voltage on both the multimeter and the gauge itself. BTW, to my knowledge, there's nothing that runs on regulated votltage on our cars, exept for some engine sensors. -------------------- |
Apr 23, 2009 - 9:06 PM
Pretty nice gauges BTW petna
Apr 24, 2009 - 10:10 AM
cheers for the info dude. thats a good one to know
They were the only gauges that took my fancy that weren't too expensive lol -------------------- www.celica-club.co.uk
My Garage |
Apr 25, 2009 - 9:10 PM
Enthusiast ![]() ![]() Joined Apr 25, '09 From Ohio, USA Currently Offline Reputation: 0 (0%) |
Wanna make me one?
-------------------- I still own my celica, but i'm parting it out and junking it.. Or selling as a whole. Have a honda prelude now :(
| Lo-Fi Version | Time is now: August 27th, 2026 - 8:30 AM |
