Apr 13, 2009 - 12:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Hey everyone,
I have a complete 4AGZE engine that I'm parting out. I have everything EXCEPT for the the block and head: Supercharger Supercharger outlet Complete MAP wiring harness Knock Sensor MAP Sensor IAT Sensor (the one that goes into the manifold) Intake manifold Metal plate that goes between the engine and transmission Flywheel Alternator A/C Compressor P/S Pump All idle and tensioner pulleys and brackets IACV TPS ABV (air bypass valve) Cam/Crank Position Sensor 1 Coil Axle carrier bearing bracket Injector resistor pack 4 Fuel Injectors Billet aluminum fuel rail (possibly aftermarket) Supercharger Relay Blue and Brown VSVs 4AGZE DLI Igniter Water temp sensor housing 168mm oversized Crank Pulley (for increased boost from the S/C) Misc brackets, etc. Let me know what you need and I'll put together a price, or make me a fair offer drtweak@phoenixtuning.com -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Apr 13, 2009 - 12:49 PM
sigh.
Apr 13, 2009 - 1:42 PM
Just keep thinking those blacktop thoughts Michelle
| Lo-Fi Version | Time is now: June 16th, 2026 - 9:17 AM |
