Apr 7, 2010 - 10:18 PM
Enthusiast ![]() ![]() Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) |
![]() here's a shot of my wheels with a wheel adaptor. Its kind of hard to specify what size would fit best. Do you want them on your stock wheels? or you wanna get after market wheels? edit: also, what offset? i think offset is the biggest factor. I drove my car to a shop, told them i needed adaptors (the rims were 5x114.3) which serve as spacers, and told them to make the wheels flush with the fender. See if they have a shop around you where they could do this for you. i pad around $250 for all 4. what are you lowered on? -------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
Apr 14, 2010 - 12:02 PM
ok guys,
which one will be more safer http://ep.yimg.com/ip/I/yhst-74684326539276_2053_4821238 or this one http://ep.yimg.com/ip/I/yhst-74684326539276_2053_4995469 the longer studs, or the double bolts This post has been edited by njccmd2002: Apr 14, 2010 - 12:04 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Apr 14, 2010 - 12:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
Id say the first one. Just make sure the bore is 56.1 or 56.X i forgot what it was, just celica sized bore and you should be right.
Apr 14, 2010 - 12:16 PM
they are celica specific.
Apr 14, 2010 - 12:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
sorry I didn't see this before,
from those links posted, the second one is the better option. here is why, on the first link, that setup has lug nuts that will be hidden behind the wheel once they are installed, if one ( or more ) is to come loose you would most likely notice it when is too late, don't get me wrong, they are safe, and people use them with sucess, but that type of setup is more suited for bolt pattent conversions, like going from 5 x 100 to 5 x 114.5 or something like that, when you are keeping the same bolt pattern longer studs are safer since you have less moving parts, keeping a closer to stock setup with only 5 nuts to worry about. you also got PM'ed edited major spelling sins This post has been edited by Culpable04: Apr 14, 2010 - 2:09 PM -------------------- ![]() |
Apr 14, 2010 - 12:51 PM
^ You have a point. And i get it now. Your right sir.
| Lo-Fi Version | Time is now: May 28th, 2026 - 9:25 AM |
