> Question About rear brakes
post Apr 14, 2009 - 10:35 PM
RavenAegis45
Joined Jun 25, '08
From CA
So I was changing my mothers rear Rotors on her 04, 4Runner and noticed her rear disk had Drums in the hub. My dad said his 85 GT-S Convertible also had Drums in the Disk hubs and he said mine would probably have Drums. I havent taken my Disk off but the hubs on my 98 GT are pretty big. So my question is do our cars have Drums inside the disk hubs?
Replies (1 - 10)
post Apr 15, 2009 - 5:55 PM
enderswift
Joined Jul 12, '08
yes the gt's do.
i was surprised to find this too back in the day when i first got my celi. i dont understand why the parking brake cant work through the caliper like alot of other cars have.
post Apr 16, 2009 - 3:18 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Toyota likes to over-engineer, which tends to be good for reliability though also why when something breaks it's not cheap.
post Apr 16, 2009 - 5:50 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
you mean the place where the e-brake shoes go????
post Apr 16, 2009 - 11:28 PM
robidunno
Joined Nov 6, '08
From San Antonio, TX
My Supra's the same. Drums are better for parking brakes because they self energize whereas Disc brakes can slip easier. Only if they're set up right though.
Rob C.
1994 Celica ST Coupe White 5 spd (temporarily)
1985 Celica Supra P Type Super White 5 spd
post Apr 17, 2009 - 6:44 AM
azian_advanced
Joined Apr 18, '05
From Calgary
actually i would rather have the disc e-brake design than our drum type. the disc type i find holds better, simpler, lighter, reliable and gives you one less set of brake pads to worry about.
post Apr 17, 2009 - 7:47 PM
enderswift
Joined Jul 12, '08
agreed ^
post Apr 19, 2009 - 2:17 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
QUOTE (azian_advanced @ Apr 17, 2009 - 3:44 AM) *
However, the dual system gives you redundancy in the case of failure; a caliper seizes and you still have a working set of brakes.
post Apr 28, 2009 - 6:24 PM
alltracman78
Joined Aug 9, '06
From Ma
And the drum brake is MUCH less likely to warp the rotor when it's set, unlike the disc brake.
You shouldn't be wearing out your E brake shoes, if you are they're probably out of adjustment.
post Apr 29, 2009 - 10:39 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Do the GTS have rear disc brakes, or are they drums too?
My Celica!
post Apr 30, 2009 - 3:47 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The GTS (Canada only) would have rear discs, with the internal drum e-brake.
Lo-Fi Version Time is now: September 12th, 2026 - 2:17 PM
