> 3sgte problems again ..............., ITS back .......it SPUTTEERS!!!
post Apr 16, 2009 - 12:13 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
Well i have a 95 celica st with a 2nd gen 3sgte swap, i recently put it back to stock ,the only mod i have is a 3inch downpipe and exhaust . Recently when i turn on the car it idles good but once it warms up it idles rough, but once you drive it runs good up until 6000rpm and sputters bad on WOT. I been driving it for a week and it shows no codes . I Took my wiring off (since in the past it has gave me problems ) and nothing i check for melted wires, loose wires, cut wire ,nothing i found nothing wrong. I change the spark plugs and wires, distributor cap and rotor and the fuel filter and still the car idles rough. I checked for compression and everything seems normal.I check for any possible vacuum leaks and nothing i found nothing. I don't get it what could be wrong?
- 02bluerolla   3sgte problems again ...............   Apr 16, 2009 - 12:13 AM
- - lagos   could be a bad afm   Apr 16, 2009 - 5:08 AM
|- - 02bluerolla   QUOTE (lagos @ Apr 16, 2009 - 5:08 A...   Apr 16, 2009 - 9:34 AM
- - lagos   QUOTE (02bluerolla @ Apr 16, 2009 - 10...   Apr 16, 2009 - 12:08 PM
- - 95celgt   ^ I love this guy LMAO!! good descriptio...   Apr 16, 2009 - 12:10 PM
- - GriffGirl   Spark plug wires? Maybe they need to be replaced o...   Apr 16, 2009 - 1:35 PM
Lo-Fi Version Time is now: September 6th, 2026 - 12:59 AM
