> FS: Random OEM 5SFE Parts, Transmission, Shifter, Cables, hubs, steering knuckles...
post Apr 21, 2009 - 1:01 PM
RichieRichJP
Joined Feb 7, '08
From Colorado Springs, CO
I'm selling parts for a 1992-1996 Toyota Camry (to be specific), but these parts also work for the following:
Toyota MR2 1990-1995 2.2L, non-turbo
Toyota Camry 1992-2001, 2.2L
Toyota Celica 2.2L 1990-1993
Toyota Rav 4 1996-1997
I have just completed an automatic to a V6 Manual swap as I'm building a stroker set up for my car.
Along with this transmission swap, I also went ahead and swapped out the rear drums to a caliper and rotor set up also.
With all of that said, here are the parts...
NEW and unmounted Lexus ES300 1997-2001 Rear Brembo Rotors (test fitted and didn't fit the way I wanted) for a drum to disc swap - $200 for pair.
CV Axles and Driveshaft, Left Right. CV Joints are good. Replaced about 30K mi. ago. $100 pair
www.megavideo.com/?v=ODJZ1VFP
www.megavideo.com/?v=XUJ4Q0PB
Automatic Shifter and shifter cable (Has some black interior paint on it) $10
Drive Pulley $15 OBO
Steering Knuckles and hubs $100 pair
Gen 3 s54 Manual Shifter $10
Rear Drum brakes $75 pair
Automatic Transmission, has about 139,800.
It is in GREAT condition, doesn't slip and works perfectly. The only problem with it is that it
leaks out of where the vehicle speed sensor is plugged in. Very easy and cheap fix.
The mechanic that I had pull the transmission out has driven the car and can tell you that it's
fully functional without any problems (except that tiny leak) whatsoever.
Here are some videos of my driving when it was in my car, days before the swap.
http://www.megavideo.com/?v=2E8AXFV2
http://www.megavideo.com/?v=IBE9B87A
http://www.megavideo.com/?v=2C12ORS1
Pictures
$350.
Pace, FL 32571
This post has been edited by RichieRichJP: Jun 4, 2009 - 1:53 PM
Lo-Fi Version Time is now: August 28th, 2026 - 2:18 AM
