> 3sgte Check engine problem (Solved), code 23
post Apr 22, 2009 - 3:39 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
Hi guyz, I have a 1995 3sgte mr2 REV 3 engine and there is a code at the ECU (code 23: MAT/Manifold air temperature), the car run VERY RICH, won<t start anymore
The problem is that when the MAT isnt connected: I have the code 23. And when i connect it, the diagnostic mode dont work, the check engine light stays on whatever I do
I tested the voltage out of the computer and when its not connected its 5V. The resistance on the MAT is 3.5kohm at 48degresF outside as the toyota shop manual says it.
When i connect it the voltage drop to 2.8V.
What would cause the ECU to freeze diagnostic mode when the sensor is plugged?
This post has been edited by domyz: Apr 24, 2009 - 6:08 AM
- domyz   3sgte Check engine problem (Solved)   Apr 22, 2009 - 3:39 PM
- - domyz   conclusion= ecu pin THAM fried, not visible on the...   Apr 24, 2009 - 6:08 AM
- - reko   Good luck le gros! Keep us informed   Apr 24, 2009 - 8:25 AM
Lo-Fi Version Time is now: August 23rd, 2026 - 9:36 PM
