Apr 25, 2009 - 3:43 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
pretty simple right?...im having lots of trouble... What parts do you recommend and explain the reason to why the part require is important. I have looked at the sticky and it tells you what do, but many have failed to list the parts needed...like a guide so if any can help, please help me list items (all) i need for relocation of battery from front to back.
so far i have on my list: *NEW battery (bigger and better Yellow Optima dual batt D31A) ![]() *0 Gauge Monster Cable 25ft (x2) ![]() *gold Terminals I don't know much about ANL FUSE blocks.... anyone care to explain? is 500 AMP enough? If it's too high, will it still be okay for my battery? I will be running stereo; let's just say a lot of electricity is needed... Any other items needed that you know of which you would recommend for this project, please list and explain why (im a noob on this and would like to know as much as i can before jumping on this project...many thanks! This post has been edited by chacha: Apr 25, 2009 - 3:45 AM |
Apr 25, 2009 - 8:45 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
you'll need something to put the battery in and bolt to the chassis.
Summit SARD Okuyama Pit Road ... or fabricate your own.. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Apr 25, 2009 - 12:17 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
Just buy yourself a Battery Box installition kit at autozone. Comes with just about everything you need to make it stay put inside your trunk.
Apr 25, 2009 - 2:05 PM
thanks...i forgotten about those boxes....what about any of the fuse blocks...do i need one or could i just wire it all the way up because i have a 0 gauge wire?
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:41 PM |
