Apr 25, 2009 - 12:56 PM
Enthusiast ![]() Joined Jan 30, '07 From canada,montreal Currently Offline Reputation: 2 (100%) |
im in the process of filling my air conditionner with this kit
http://www.redtek.com/products_refr.html# im looking for the high pressure nozzle and the low pressure one i think this one is the low pressure but i want to make sure and i dont know where is the high pressure ![]() ![]() thank you (and i do know my engine is really dirty) This post has been edited by chode: Apr 25, 2009 - 12:57 PM -------------------- ![]() |
Apr 25, 2009 - 1:00 PM
![]() Enthusiast ![]() ![]() Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
the fat a/c line is the low pressure, and the small a/c line is the high pressure, just look around, just follow the lines till u find anouther fitting that looks like the one u found already.
-------------------- Lift Addict!! ^_^
Apr 25, 2009 - 1:17 PM
thank you very much
ill go check it out -------------------- ![]() |
Apr 25, 2009 - 1:29 PM
the only thing on the smaller hose are the wire circle in red
the small one goes all the way to the engine coolant systeme
Apr 25, 2009 - 2:17 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
i think it's at the front of the car between the bumper and the radiator... i'm not too sure i'd have to go to the car and find out....
Apr 25, 2009 - 2:24 PM
the blue circle is the low pressure fitting, the high pressure fitting should be on the smaller line around the front of the car, just trace that little line down, and u will find that other fitting
Jul 7, 2009 - 4:21 PM
Enthusiast ![]() Joined Aug 13, '07 From Arizona Currently Offline Reputation: 1 (100%) |
Im having the same problem i followed the line and cant find the high pressure all i can find is the low pressure can anyone help that has info on this please and thank you =)
Jul 7, 2009 - 4:35 PM
NVM I FOUND IT!!!!
Jul 7, 2009 - 10:06 PM
needs cleaning and yes thats the L nozzle., where is the cap
Jul 9, 2009 - 10:57 AM
I dnt understand the question but if you look in pic right by the driver side low beam youll see the cap its like a gray color
I dnt understand the question but if you look in pic right by the driver side low beam youll see the cap its like a gray color |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 6:55 AM |
