> help please! Power Main Relay?, Can't seem to locate it=S
post Apr 25, 2009 - 1:17 PM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
As some of you guys know I am working on a DIY for the quarter windows for the verty.
On the test run to see if the windows works or not, one of the problem that came up was the switch.
I removed the switch and was playing around with the wires because i was trying test the windows. welll what happen was all the wires touched each other. and bam.... windows dont work anymore....
I've check all fuses none are blown. (POWER FUSE AND GAUGE FUSE suppose to be the suspects but they are fine)
I need to check my POWER MAIN RELAY. The picture shows it being in the inside fuse panel, but which one or am even looking at the right one.
On the opposite side of the inside fuse panel there are three black relays? could this be one of them?
THANKS GUYS...
this blows.. it was the 1st time in 2 years i was able to have all the windows down.
Lo-Fi Version Time is now: June 10th, 2026 - 4:47 AM
