Apr 25, 2009 - 2:28 PM
![]() Enthusiast ![]() ![]() Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
So my windshield wiper motor blew and since i had another one from a 94 gt i decided to change it.
Now here's the prob: you know the wiper control arm (or wtv you call it) needs to be all the was to driver side for the wipers to be at starting position (so they will go up and down). Now this thing on the left (i know its not from a celica) ![]() as to be mounted on the wiper motor but its too far from the little hole for me to reach it... and when the wiper motor is at starting position, the pin is facing the ground... not the driver side... http://img19.imageshack.us/my.php?image=45083534.jpg Wiper motor starting position... to fit with the wiper arm, the ''thing" should be in front of the black part... http://img19.imageshack.us/my.php?image=64757770.jpg I've been working on this for like an hour and still cant find the solution... anyway can help me asap? It's suppose to rain tomorow This post has been edited by reko: Apr 26, 2009 - 11:07 AM -------------------- |
Apr 25, 2009 - 5:05 PM
Enthusiast ![]() ![]() ![]() Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) |
i have no idea, but if it looks like you're not gonna get it fixed, I'd RainX the windshield and you can probably get by without the wiper.
-------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Apr 25, 2009 - 9:29 PM
Enthusiast ![]() ![]() ![]() Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
The shop manual has the correct procedure and I don't remember it in detail but it goes like this:
1. You run the wipers and stop with the key at a certain position, NOT the park position. 2. You remove the cowl panel 3. You clip one of the linkages in place, don't remember which 4. You disconnect at one of the joints, again don't remember which. 5. You remove motor, don't remember if one of the links stays attached to the motor Shop manual makes it very easy if you follow it. |
Apr 26, 2009 - 11:01 AM
Problem fixed; the metal piece that connects the motor to the wiper control arm wasnt at the right angle when at starting position... seems stupid but the bolt was so tight that i wasnt able to take it off since it was making the motor turn every time i tried with the ratchet... so i thought it was welded... so i ended up using a pipe wrench (which i didnt thought at first) and it worked on the first attempt
| Lo-Fi Version | Time is now: September 1st, 2026 - 10:56 PM |
