> rear brake rotors, Not sure if mine are the right size
post Apr 29, 2009 - 10:03 PM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
So I'm installing new e brake pads and have been having issues getting my rotors back on. The previous owner I believe did a rear brake swap because I have rear disks but the car is an st. What size are the stock gt rotors in the rear? Everything is all centered up and the rotors still aren't sliding on over the ebrake pads. I promise this will be my last post about this smile.gif
Replies (1 - 2)
post Apr 30, 2009 - 3:42 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Have you dialed the e-brake adjuster all the way back? There will be a notched gear at the bottom of the e-brake assembly which controls the spread of the e-brake pads. Once the rotor is on, you can access the gear through a hole in the face of the rotor to adjust the pads back into position.
Rear rotor dimensions:
94-95: 269 mm diametre, 10 mm thick, 55 mm centrebore
95-99: 269 mm, 9 mm, 55 mm
post Apr 30, 2009 - 7:51 AM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
Thanks for the reply. Yeah, I have the e-brake adjuster all the way back and still no fit. Pads seem to be centered and even if I managed to get the rotor back on over them it would be one tight fit, that's why I'm thinking I have mismatched parts. I think I'm just going to put the old pads back on and just play with the adjustment until the e-brake hold better.
Lo-Fi Version Time is now: September 12th, 2026 - 2:17 PM
