> Would it be feaseable
post May 5, 2009 - 12:40 PM
reko
Joined Apr 17, '07
From Montreal, QC, Canada
http://cgi.ebay.ca/JDM-95-OEM-Celica-GT4-T...p3286.m20.l1116
Would it be possible to buy this kit which includes front clip and rear clip and install the rear onto a ST204 GT-S ? Would the rear subframe and gearbox differential fit onto my current frame (if i remove the gaz tank) ? Or it would require major work to the chassis?
And what about the driveshaft?
I searched on the database but mostly found front end conversion... and the only owner of a converted to AWD here that i've found is celiman05 and he havent logged in since august 2008!
This post has been edited by reko: May 5, 2009 - 2:09 PM
- reko   Would it be feaseable   May 5, 2009 - 12:40 PM
- - pittfirefighter   several members have already done it   May 5, 2009 - 12:41 PM
|- - reko   QUOTE (pittfirefighter @ May 5, 2009 - 1...   May 5, 2009 - 1:54 PM
- - eggman40   im not completely certain but i know that it requi...   May 5, 2009 - 2:08 PM
- - reko   Yeah i found the thread like an hour after, thanks...   May 5, 2009 - 3:40 PM
- - azian_advanced   you could cut the rear trunk flooring and weld the...   May 5, 2009 - 8:23 PM
- - alltracman78   If someone is going to do an AWD swap, this is the...   May 5, 2009 - 11:18 PM
|- - stephen_lee   QUOTE (alltracman78 @ May 5, 2009 - 11...   May 6, 2009 - 9:13 AM
- - Culpable04   QUOTE (azian_advanced @ May 5, 2009 - 9...   May 6, 2009 - 7:51 PM
- - azian_advanced   btw, this project was completed...   May 7, 2009 - 8:07 AM
- - Culpable04   so he basically cutted at the welding points and r...   May 7, 2009 - 8:34 AM
- - presure2   that is without a doubt the best way of doing it. ...   May 7, 2009 - 8:53 AM
- - lagos   ^ F@#k that!   May 7, 2009 - 9:09 AM
|- - _Jim_   QUOTE (lagos @ May 7, 2009 - 10:09 A...   May 7, 2009 - 6:08 PM
- - reko   damn never thought of doing this. Seems way better...   May 7, 2009 - 9:24 AM
- - azian_advanced   the sides were cut because the gt-four has differe...   May 7, 2009 - 4:55 PM
- - pipes   sometimes i wonder with you guys am i just chopped...   May 7, 2009 - 5:03 PM
- - domyz   i would not do this, this is illegal, insurance co...   May 7, 2009 - 5:07 PM
|- - pipes   QUOTE (domyz @ May 7, 2009 - 6:07 PM...   May 7, 2009 - 5:13 PM
- - presure2   this mimics the factory in that it uses all the fa...   May 7, 2009 - 6:22 PM
|- - _Jim_   Easier ways, yes Better or WORSE, no If the pro...   May 7, 2009 - 6:32 PM
- - lagos   QUOTE (presure2 @ May 7, 2009 - 7:22...   May 7, 2009 - 9:32 PM
|- - 95st-celica   QUOTE (lagos @ May 7, 2009 - 10:32 P...   May 7, 2009 - 10:30 PM
- - lagos   sorry joe, but the diy mechanic cant weld as well ...   May 8, 2009 - 12:14 AM
- - 95st-celica   not sayin i would try this on my car...but if i we...   May 8, 2009 - 12:21 AM
|- - reko   QUOTE (95st-celica @ May 8, 2009 - ...   May 8, 2009 - 7:51 AM
- - presure2   art, its really not that hard to duplicate the fac...   May 8, 2009 - 8:11 AM
- - playr158   come on we can use mine as the guinea pig if Manny...   May 8, 2009 - 9:01 AM
Lo-Fi Version Time is now: July 29th, 2026 - 6:53 PM
