May 6, 2009 - 3:05 PM
Enthusiast ![]() ![]() Joined Jul 23, '08 From Hawaii Currently Offline Reputation: 6 (100%) |
Picked up a scanner the other day to start fixing the last big problem on the car.
I already took off and cleaned out my EGR valve as best I could, but on the scanner, I noticed it flashes EGR and CAT. avg speed it trips is 35-41mph and I have the other readouts if needed to help with the troubleshooting. anyone have any other ideas? O2 sensor? Intake manifold? |
May 6, 2009 - 11:03 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
P0401 and P0420?
Your EGR valve and cat are probably bad. Replace them. The codes are unrelated, unless a wiring harness is damaged somewhere. But that still wouldn't give you P0420. -------------------- ![]() |
May 7, 2009 - 3:13 PM
P0401 is the fault.
how expensive are the parts? |
May 7, 2009 - 5:40 PM
Just P0401?
Then what does the cat have to do with it? -------------------- ![]() |
May 8, 2009 - 10:36 AM
![]() Enthusiast ![]() ![]() ![]() Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) |
ok wait. When you were driving around with the tester in, the little icons for EGR and CAT where flashing? That usually means that the ECU hasn't completed a test cycle on it since you plugged it in. Don't worry about the flashing icons, worry about CEL codes that are thrown.
You have the same code my EGR system was throwing a month ago. I ended up replacing my EGR valve, EGR modulator and the hose that connects the two. You could take your EGR to a mechanic and get them to vacuum test it for you. After replacing my EGR, the CEL came back a week later so I just decided to get a new modulator as well. It's been a month now and I'm CEL free. The modulator has a small foam filter in the top of it you can try to replace, but it didn't do anything for me. 1sttoyotaparts.com has great prices on the two parts, but expect to spend $47.95 for a modulator or $148.06 for the valve. This post has been edited by Sinyk: May 8, 2009 - 10:41 AM -------------------- |
May 8, 2009 - 2:49 PM
the last couple times I connected the tester, only the EGR was flashing...
I already took my egr valve out and dunked in my solvent tank at work and tried to scrub out the inside...but I guess it didn't work. do you remember the part number for the modulator? I can start there and replace the valve after. weird cause it still looks pretty new. |
May 8, 2009 - 3:07 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 14, 2009 - 10:38 PM
an update....
replaced the EGR modulator and fault still tripped, so I was able to return the modulator and replaced the EGR valve with a new one. Fault still tripped....any other places I could look? |
| Lo-Fi Version | Time is now: August 29th, 2026 - 3:41 PM |
