> Hose diagram, 3sgte diagram to be exact
post May 8, 2009 - 12:50 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Hello, does anyone happen to have a hose diagram for the 3rd gen 3sgte...recently i have been having a coolant leak coming from my throttle body, and i suspect that i may of re-routed the coolant lines wrong, after re-installing my engine..i have tried swapping them around and am about ready to tear back into it all to figure out whats going on....would be handy to have a diagram though, if there even is one...
(\__/)
Replies (1 - 4)
post May 8, 2009 - 6:11 AM
check the resource site as it has a 3sgte BGB book.
post May 9, 2009 - 9:31 PM
3WayStunna
Joined Jun 25, '06
the resource site? hmm, where can i find that at again?
(\__/)
post May 15, 2009 - 3:04 AM
3WayStunna
Joined Jun 25, '06
Err not resurect a dead thread, but i found a fix to my problem....seems that one of the two hoses, that run engine coolant through the throttle body, was leaking...BAD!!!
So i just ended up re-routing the lines away from the TB, and into each other...basically connecting them together. Doubt ill have that leaking problem again...oh and i used a new hose! I also hear that i get to enjoy lower intake temps YAHH!!
(\__/)
post May 15, 2009 - 6:26 AM
QUOTE (3WayStunna @ May 15, 2009 - 3:04 AM) *
yup, thats no problem to do.
the only issue you may notice is that it may take a few extra minutes for the idle to kick down to normal on a cold morning.
Lo-Fi Version Time is now: September 19th, 2026 - 2:20 AM
