Oct 16, 2003 - 1:57 PM
Enthusiast ![]() ![]() Joined Feb 18, '03 From Hermiston, OR Currently Offline Reputation: 0 (0%) |
Recently my car started running poorly at low rpms, like idle to maybe 2k or so. If I stomp on the gas from idle (stopped) it hesitates before gaining rpm's. runs fine driving above about 2k. Below 2k, like taking off from a stop is really gutless until it hits 2k. It kinda jerks the car sometimes as it hesitates. Thats what the car is doing. here is a little about the condition. It's a '94 GT (no mods) w/ 115k miles. At about 100k miles I changed the fuel and air filter, plugs, wires, cap, and rotor. I'm not sure if the timing belt has ever been done. I pulled the plugs out and they look fine. gap is ok. checked the cap and rotor. They looked fine but I replaced the rotor anyways. Checked air filter. It is still fine. Any ideas? a sensor maybe?
klr_toy low rpm 5s-fe hesitation Oct 16, 2003 - 1:57 PM
Supersprynt put some fuel injector cleaner in. Oct 16, 2003 - 4:51 PM
1bwilson QUOTE (Supersprynt @ Oct 16, 2003 - 2:51 PM) put s... Oct 16, 2003 - 11:54 PM
snadman Better yet, run a can of seafoam. Oct 17, 2003 - 1:02 AM
GeEkBoY could be the ignition coil, my car was doing that,... Oct 17, 2003 - 2:17 AM
jayi12-15psi is your check engine light on?
it could be a o2 s... Oct 17, 2003 - 11:28 AM
klr_toy I did run a bottle of injector cleaner through it ... Oct 23, 2003 - 4:53 PM
celicagt94 Sometime when i stop and then hit the pedal the ca... Oct 23, 2003 - 10:15 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 20th, 2026 - 2:48 PM |
