> 3SGTE into Convertible
post May 14, 2009 - 3:55 AM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Hey all, Been in the process of dropping a rev3 3SGTE into my droptop - was a 3SGE. Using a GT4 gearbox with MR2 bellhousing and MR2 LSD. Used all ST205 engine mounts.Just need the bracket for the longer driveshaft. Going to use ST185 brakes all around with redstuff brake pads. Walbro fuel pump and std 540 injectors, front mount intercooler and MR2 rev3 ECU. Wireing harness is ST205 item and is plug and play, only problem is that there is no fuelpump relay in the harness near the battery. Had to hardwire the fuelpump to get it started - is this normal or is my harness different??
This post has been edited by jeffrosie: May 14, 2009 - 3:56 AM
Lo-Fi Version Time is now: July 10th, 2026 - 1:00 PM
