May 17, 2009 - 1:19 AM
Enthusiast ![]() Joined Oct 20, '08 From Lima,Peru Currently Offline Reputation: 0 (0%) |
hi
ive been reading a lot of this...i recently own a beams rep top engine for my AT180 the engine is totally swaped..finally heres my doubt...i want to turbo my beams...i know its a high compression engine...so it need low compression pistons but ..does anyone know who can make me some forged pistons? what else should i need besides that? vvti have to be removed? from what ive read i know there are 2 succesfull turbo-beams..the hks and..a guy i think hes from uk thought and altezza-black top and 3sgte pistons wont fit...=( any ideas? does anyone have some info about this project? thanks in advance paul =) This post has been edited by paul52: May 17, 2009 - 1:23 AM |
paul52 turbo beams?? May 17, 2009 - 1:19 AM
azian_advanced but if you look closely to the pic of the HKS Beam... May 17, 2009 - 3:33 AM
Cuts_the_Pilot you could leave it high compression and run low bo... May 17, 2009 - 4:45 AM
Dragondog doing this to the beams will it still out pwr the ... May 17, 2009 - 1:43 PM
delusionz I wouldn't mind VVT-i on my engine...when toyo... May 17, 2009 - 2:07 PM
crankyelbow A low boost turbo beams would spool very very quic... May 17, 2009 - 2:25 PM
Dragondog how well will the beams head work swaping it on th... May 18, 2009 - 5:16 AM
delusionz Buy me one and I'll let you know May 19, 2009 - 5:35 PM
Cuts_the_Pilot turbo high comp beams=good spool good off boost pe... May 20, 2009 - 12:40 AM
Rusty QUOTE So when you pushing big numbers and not usin... May 20, 2009 - 2:26 AM
delusionz why would you disable vvt-i? i'd just change t... May 20, 2009 - 5:02 AM
Cuts_the_Pilot im only assuming the beams cams are slightly more ... May 20, 2009 - 6:07 AM
Dragondog iv read that the 3sgte was basicaly a replacment o... May 20, 2009 - 6:10 AM
Rusty QUOTE im only assuming the beams cams are slightly... May 21, 2009 - 3:42 PM
Cuts_the_Pilot the early vvti are crude and only choose between a... May 21, 2009 - 4:34 PM
Rusty 2. gen 3SGE
In: 244deg, 8.5mm lift (timing 7/57)
... May 21, 2009 - 8:26 PM
Cuts_the_Pilot good work rustus, interesting to note the differen... May 22, 2009 - 10:55 PM
Rusty plus if your using the head I think you need the b... May 24, 2009 - 2:14 PM
paul52 ive been in exams i didnt have time to log in and ... May 24, 2009 - 9:01 PM
Cuts_the_Pilot If you reckon OE pistons wont fit what makes you t... May 25, 2009 - 1:39 AM
Dragondog im getting lost in the whole upgrading beams thing... May 29, 2009 - 5:49 AM
Rusty I'm having a bit of trouble understanding that... May 29, 2009 - 5:30 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 19th, 2026 - 1:57 PM |
