May 18, 2009 - 8:05 PM
Enthusiast ![]() Joined Feb 18, '07 From Calgary, Alberta Currently Offline Reputation: 0 (0%) |
Ever since I bought my car, I had a ISB problem. Since I am swapping out my motor for a 98 spec 5S getting ready for a FTE setup, I want to change the input shaft bearing. I have looked at the service manual and it isnt too descriptive of how it comes out. Has anyone done this before? Thanks
May 20, 2009 - 2:01 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
You've got to take the whole transmission apart.
IIRC you need to remove all the gears/bearings on the input shaft, I wouldn't recommend doing this yourself. You should replace both bearings on the shaft while you're at it. When you press off a bearing it's very easy to damage it. -------------------- ![]() |
| Lo-Fi Version | Time is now: July 30th, 2026 - 6:08 AM |
