> Want to remove air condition, I'm crazy..... you know...
post May 29, 2009 - 3:51 PM
Temporary-Failur...
Joined May 27, '09
From Finland
So I have -95 HB 2.0 GT and I want to remove AC because I want to save some weight. What I should do and how?
post May 29, 2009 - 4:14 PM
QUOTE (Temporary-Failure @ May 29, 2009 - 3:51 PM) *
get a non ac belt, and you can remove the a/c compressor, condensor, accumulator, and all the lines in the engine bay assosiated with the system.
there is a sensor attached to a line close up by the firewall, you need to leave that sensor connected, or your fans will run constantly.
just unscrew the sensor from the line, and leave it plugged into the harness.
Lo-Fi Version Time is now: August 21st, 2026 - 10:30 PM
