May 31, 2009 - 5:43 PM
Enthusiast ![]() ![]() Joined Feb 7, '08 From Colorado Springs, CO Currently Offline Reputation: 0 (0%) |
A piece to my collection of parts is the Visteon Racing Radiator. The only use that it ever had was to be tested for leaks. So this radiator probably saw no more than 5 miles. Being a one-of-a-kind radiator, it was obviously pricey, almost $700 pricey. This is a must for you turbo guys!
Fits: Toyota Celica 1990-1999 Toyota Camry 1992-2001 it may fit other years and models, but these are models and years I know for sure that it will work on. Basically, the radiator is lightweight and double the thickness and will allow for a lot better cooling for your engine. This radiator was built from a core for a 2000 Mitsubishi Eclipse and modified to fit 5SFE model cars. For any other car it may fit, the simple solution to make it work would be through routing the houses and adjust the height that it sits. The radiator comes with a SPAL fan, a MOROSO radiator cap, clamps, and a hose. Price:$375 + shipping ![]() ![]() ![]() ![]() Visteon's Homepage "Enthusiasts and racers everywhere will welcome the engineering and craftsmanship that go into Visteon Performance Radiators. They provide superior performance, offer a flawless finish and require less installation time. Designed for hardcore racing and ultimate street performance, Visteon Performance Radiators are handcrafted using engineering racing cores and heavy gauge aluminum stock - just like the radiators used in NASCAR. Visteon Performance Radiators are made with advanced technology 26mm, 36mm, and 56mm racing cores. The tanks are fabricated by hand from die-cut, aircraft quality polished aluminum. Sport compact radiators are built with welded fan mounts and come complete with a Spal electric fan, drain plug and radiator cap. Every model is assembled and tested for superior heat rejection." Pace, Fl 32571 This post has been edited by RichieRichJP: Jul 31, 2009 - 6:07 PM -------------------- |
RichieRichJP FS: Toyota Celica 1990-1999 custom Visteon Racing Turbo Radiator May 31, 2009 - 5:43 PM
RichieRichJP 'Cheap Ebay radiators are refurbished, knock-o... Jul 31, 2009 - 11:32 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:06 AM |
