May 31, 2009 - 7:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
for all you 3s guys, when you do an oil change, how long does it usualy take to burn a quart of oil through your motor? i put my first 4 1/2 quarts in when i did the swap, noticed it was a little low, and put the other 1/2 quart in to top it off....that was about a month ago, i looked today, and its about 1/4 full on the dip stick, right above the L...i know they burn oil, and i know i drive my car a little hard, but i was wondering if this is normal for the 3s motor
thanks guys -------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
May 31, 2009 - 7:55 PM
Enthusiast ![]() ![]() Joined Jul 29, '07 From Quebec, Canada Currently Offline Reputation: 0 (0%) |
I put 1/4 of a liters every 3000 miles (between 2 oil changes, I use 5w40 in gen3 3sgte) , this is normal turbo seal consumption
a little more than this is not a big problem, probably your ct26/ct20b seal This post has been edited by domyz: May 31, 2009 - 7:55 PM |
Jun 5, 2009 - 1:04 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Didn't you do a rebuild before you swapped the engine? Also did you rebuild the Turbo? Do you have an oil catch can with a level gauge on it?
-------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Jun 5, 2009 - 8:28 AM
we redid all the seals on the engine.
first thing to check is to make sure none of those seals are leaking for some odd reason. next, because of the large amount of shaft play on your turbo, its probably burning oil from the turbo seal. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 5, 2009 - 8:43 AM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
yeah i agree with lagos turbo seals..just see if there is black smoke comin out of the exhaust when u drive
Jun 5, 2009 - 9:41 AM
yea im pretty sure its my turbo..because the whole under side of the car is covered in carbon, and even in the bay a little bit...due to the open DP. makes sense, thanks guys.
Jun 7, 2009 - 10:29 AM
hmmm.. a bad turbo would cause blue smoke, not black smoke . Black is fuel(running rich) , blue is oil(turbo seal)
Jun 7, 2009 - 10:45 AM
Enthusiast ![]() Joined Mar 2, '08 From Manchester - UK Currently Offline Reputation: 0 (0%) |
my 3s doesn't seem to burn any. Do an oil change every 3k-5k though
-------------------- www.celica-club.co.uk
My Garage |
| Lo-Fi Version | Time is now: September 19th, 2026 - 9:26 PM |
