Jun 6, 2009 - 5:12 PM
hey guys i have a blue garage, from paint overspray. (spray gun) the floor is blue.
whats the best solution. thats not gas or thinner. are there any biodegradable solutions that i could use? yes i was painting a couple of things and my strut bar.... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jun 6, 2009 - 8:13 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
unfortunately there is no easy solution to this
Good luck -------------------- ![]() |
Jun 7, 2009 - 8:14 AM
hey guys i have a blue garage, from paint overspray. (spray gun) the floor is blue. whats the best solution. thats not gas or thinner. are there any biodegradable solutions that i could use? yes i was painting a couple of things and my strut bar.... welcome to the club!!! -------------------- Former Team 5SFTE pro member ;)
Jun 7, 2009 - 10:04 AM
paint over it.
Jun 7, 2009 - 11:40 AM
Enthusiast ![]() ![]() ![]() Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
Go to the store and buy some low-toxicity, bio-degradable paint stripper. Meaning one that doesn't contain methylene chloride.
It will remove most paints, but if you used catalyzed urethane you're likely SOL. |
Jun 7, 2009 - 12:09 PM
Go to the store and buy some low-toxicity, bio-degradable paint stripper. Meaning one that doesn't contain methylene chloride. It will remove most paints, but if you used catalyzed urethane you're likely SOL. good idea, but this will also strip the original paint of his garage. -------------------- ![]() |
Jun 7, 2009 - 1:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
If you can find Citri-solve mix a quart of that to a gallon of water. throw it everywhere and lightly scrub, it should come off.
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 7, 2009 - 7:15 PM
will try tgw citri solve.
my garage floor is bare cement, and im about to leave the house and put it up for rent, it really looks ugly. used the valspar paint i dont think its urethane -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jun 7, 2009 - 8:56 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
you can use sand paper on bare cement.... i spilled a whole bunch of oil/tranny fluid/power steering fluid and that way worked the best... just takes some time
-------------------- Breaking Axles...
Jun 8, 2009 - 11:15 PM
Enthusiast ![]() ![]() Joined Mar 19, '09 From Malden, MA Currently Offline Reputation: 2 (100%) |
I second the sand paper motion, so long as it's just flat concrete, which most garages are, sand paper does wonders. Just get a random orbital sander and go at it with some fairly aggressive stuff.
Jun 9, 2009 - 6:36 AM
Enthusiast ![]() Joined Mar 14, '09 From Portishead Currently Offline Reputation: 0 (0%) |
If you don't liek the colour for whatever reason: paint over it.
Else: who cares? its a garage! they get black/brown in no time if used regularly |
Jun 9, 2009 - 2:44 PM
good idea, but this will also strip the original paint of his garage. Not usually. A professionally painted garage floor will be either catalyzed urethane or a specialty epoxy. A mild stripper like the orange/citrus stuff won't touch that. If the floor paint was a DIY job, then yes, it will be stripped. |
Jun 12, 2009 - 3:31 AM
good idea, but this will also strip the original paint of his garage. Not usually. A professionally painted garage floor will be either catalyzed urethane or a specialty epoxy. A mild stripper like the orange/citrus stuff won't touch that. If the floor paint was a DIY job, then yes, it will be stripped. he said overspray. im taking he sprayed his car. i dont think car paint is epoxy. that "citrus stuff" took off alot of different paints on my garage floor. house paints, car paints, etc. This post has been edited by 808celica: Jun 12, 2009 - 3:32 AM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 12, 2009 - 5:36 AM
![]() Enthusiast Joined Feb 28, '09 From QLd, Australia Currently Offline Reputation: 0 (0%) |
Try a pressure cleaner on the floor.....just be careful as it will take off some concrete...
| Lo-Fi Version | Time is now: July 6th, 2026 - 2:02 AM |
