> Hello and brief question
post Jun 7, 2009 - 12:50 PM
Glacyus
Joined Jun 7, '09
I am a 6gcelica owner, and a recent lurker of these forums. I am just starting my tinkering with the Celi, so forgive newbie questions, including the one in this post.
I had my passenger side window not work, so I swapped the 30amp fuse in the kick panel with the one for the rear window defogger, and that fixed the problem. The fuses are not burned, but I did notice a greenish corrosion on all three 30amp and one 40amp fuse in there. I tried purchasing new fuses at a local parts store, only to find they didn't fit. The only other similar fuse had the same problem, the socket blades fit parallel, not staggered like the fuse I needed. Before I try other parts stores, would someone happen to know the name or designation of our fuses? I've looked everywhere for the answer, including repair manuals with no avail.
Thank you.
post Jun 8, 2009 - 3:08 PM
Glacyus
Joined Jun 7, '09
A link to an online shop that sells these fuses would do as well if anyone knows.
post Jun 8, 2009 - 3:13 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Grainger is a leader in electrical supplies, I get some odd fuses there myself for radio transmitters. I'm sure they'd have the am2 30amp.
The fuse part number is: MIN10BP
If you google that there should be a large amount of providers for that fuse, atleast from what i've googled! Good luck sir!
This post has been edited by rave2n: Jun 8, 2009 - 4:13 PM
Lo-Fi Version Time is now: August 27th, 2026 - 2:31 PM
